Old 08-16-2015, 01:14 AM   #1
pooch
pooch's Avatar
Default 34 gearbox to model A torque tube
Does/can a 34 gearbox mate to a standard model A torque tube/uni joint ?
pooch is offline   Reply With Quote
Old 08-16-2015, 09:06 AM   #2
Fred A
Fred A's Avatar
Default Re: 34 gearbox to model A torque tube
Yes
Fred A is offline   Reply With Quote
Old 08-16-2015, 10:58 AM   #3
Charlie Stephens
Not knowing the whole project I am going to take a shot in the dark and add a bit to Fred's post. Remember that the mount for the brake and clutch pedals and the mount for the wishbone is not on the '34 transmission. You will have to fab something.
Charlie Stephens
Old 08-16-2015, 05:08 PM   #4
pooch
pooch's Avatar
Thanks,
The project is just getting a bunch of leftover parts into a going roller to flip.
Model A chassis with front and rear ends and I have a set of 16 inch wires and a 21 stud late 36 motor and 34 gearbox to throw into it.
I may or may not fab some pedals to make it a complete driver, will see how it pans out.
Old 08-16-2015, 05:15 PM   #5
redmodelt
redmodelt's Avatar
You can buy the brackets to mount the pedals from some of the parts sellers.
Old 08-16-2015, 05:16 PM   #6
skidmarks
skidmarks's Avatar
F1 crossmember and pedals is the easiest way to do it will all old ford parts.
skidmarks is offline   Reply With Quote
Old 08-16-2015, 05:20 PM   #7
mrtexas
mrtexas's Avatar
You will need a bell housing spacer to fit a v8 transmission to a Model A torque tube. The usual suppliers sell the kit for $475. It also includes the brackets for pedals and e brake handle.
mrtexas is offline   Reply With Quote
Old 08-16-2015, 07:10 PM   #8
skidmarks
skidmarks's Avatar
Do you mean if your using a model A motor?
Old 08-17-2015, 03:31 PM   #9
CT AV8
CT AV8's Avatar
Pooch, it will bolt right up but you need to use the V8 torque tube bell vs the Model A. I did it with a '35 gearbox.
CT AV8 is offline   Reply With Quote
Old 08-17-2015, 10:06 PM   #10
skidmarks
skidmarks's Avatar
I got one with a 39 trans and a model A rear. All I can think of that was mentioned above was the kit with the aluminum bell housing adapter to bolt a model A motor to a V8 transmission
Old 08-18-2015, 03:24 AM   #11
Hoop
Hoop's Avatar
1. The V8 and Model A use the same U-joint. The "clamshell" pieces that bolt the transmission to the torque tube must be the 4-bolt V8 style rather than the 6-bolt Model a style ... easy.
2. Cling's has the adapters for the wishbone (unless you plan to split the bone), pedals, and e-brake which they sell separately.
https://www.clingsaftermarket.com/pr...=Transmissions
3. If you are using the V8, of course you will not need a bell housing adapter.
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
