Old 08-14-2015, 08:11 PM   #1
Steve Plucker
Default Diode vs. a non-diode cutout...
What is your preference...the use of a diode within the cutout or the original assembled cutout in your Model A and why?
Thanks.
Pluck
Old 08-14-2015, 08:42 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Diode vs. a non-diode cutout...
If done right, a diode is more reliable than a reproduction cutout. They are junk.
A restored original mechanical type cutout is quite good and I don't mind using one, if you have one. The problem is they are hard to find in good condition and most people don't know how they work, how to adjust them, etc. No moving parts on a diode, so easy to use.
With the mechanical style you have to train yourself to look at the ammeter regularly to spot if the cutout is stuck open or shut. We've gotten out of the habit of doing that on modern cars (which don't even have an ammeter any more!).
Jim Cannon
Former MAFCA Technical Director
"Spread the Joy! Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 08-14-2015, 10:37 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
There are technically 3 types of cutouts: original and reproduction mechanical units and the diode type.
As Jim mentioned, the reproduction ones are junk, anything is better than junk. We say junk because the manufacturer cut corners in the amount and gauge of the wires used in the magnet, and the materials in the contacts. That leaves original and diode.
The diode is reliable, never needs adjustments.
I like the idea of using an original unit. They are robust, reliable, easy to restore and easy to fix, although I know of owners that have had their cars for 40+ years and they never failed, mines been on the car since the 80's and never a problem.
Old 08-15-2015, 06:45 AM   #4
Mitch//pa
i have not had the diode style fail on me yet, but had plenty of the mech /original style cause issues.
Old 08-15-2015, 07:07 AM   #5
mlp623
mlp623's Avatar
I switched to diode as well and have no problems. I like that it still has an original look but more modern function. It seems to be a good quality part and that seems worth paying for.
Matt
mlp623 is offline   Reply With Quote
Old 08-15-2015, 10:20 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
I converted my cutout 35 years ago with a used alternator diode, never any problems with it
There is an advantage to the diode cutout, I have hand crank started the car with a bad battery, a good brisk pull on the carnk makes almost 4 volts and has been enoughto start the engine with a battery having only 2volts
Old 08-15-2015, 11:52 AM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Diodes DO cause a small voltage loss, BUT it seems to be of NO CONSEQUENCE.
HOW/WHY a diode works used to boggle my mind, I even sawed one in half???--Found my "LAYMENS" answer, in an old ENCYCLOPEDIA!--Just found the name of the leg bone I BROKE, in there too!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-15-2015, 01:59 PM   #8
mshmodela
mshmodela's Avatar
Thus far happy with my solid state cutout from Berts (Made in USA).
https://www.youtube.com/watch?v=v1Z3QpOlN74
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 08-15-2015, 02:32 PM   #9
BILL WILLIAMSON
Diodes are CHEEP & you can gut out your cut-out & solder it in yourself! IF you can't solder, in one LOOOOOOONG sentence, I can present you a "SOLDERING-101"
Bill W.
Old 08-15-2015, 03:10 PM   #10
al's28/33
al's28/33's Avatar
Diode cut out for reliability with my original powerhouse generator and EVR unit set-up by Thomas Wesenberg...that's the ONLY way to Fly!!!!
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 08-15-2015, 03:25 PM   #11
mrtexas
mrtexas's Avatar
Bill W.
Want to know how a diode works take Physical Chemistry. Has to do with electrons and holes.
mrtexas is offline   Reply With Quote
Old 08-15-2015, 04:51 PM   #12
BILL WILLIAMSON
Yes, I read about the "holes", etc, FASCINATING stuff!
Bill W.
Old 08-15-2015, 07:43 PM   #13
glenn in camino
glenn in camino's Avatar
Modern electronics is a little like modern medicine. Way better than the old ways.
glenn in camino is offline   Reply With Quote
Old 08-15-2015, 09:19 PM   #14
ian Simpson
Using a diode is a big step up in reliability over a mechanical cutout, but I went one better and use a proper solid state regulator that looks after the battery without me constantly checking the ammeter. Mine came from our local supplier, George Moir, in Stoney Plain, AB. (http://georgemoir.ca/)
I think Snyders have a similar product.
ian Simpson is offline   Reply With Quote
Old 08-15-2015, 09:25 PM   #15
MrTube
MrTube's Avatar
I can kind of see why some would want the original setup, but at the same time the diode is infinitely more reliable and would you ever notice the difference?
I installed a solid state start relay on my 1933 fridge and I'm kinda sad I did because you don't hear the relay click everytime it starts. But, at the same time, it's probably more reliable.
MrTube is offline   Reply With Quote
Old 08-15-2015, 09:45 PM   #16
Mike V. Florida
hang a mechanical relay off the solid state one just to get the click.
Old 08-15-2015, 10:18 PM   #17
MrTube
MrTube's Avatar
Nice.
Still not the same.
Old 08-15-2015, 10:22 PM   #18
Steve Plucker
Got to love that fridge...Not many around that work that is for sure.
Good job on restoring it!
Hope my gas pumps look the same when I get to them except I have gutted them for the most part.
Pluck
Old 08-15-2015, 10:29 PM   #19
53RYDER
Newbie here! What's a cutout do?
Glenn
53RYDER is offline   Reply With Quote
Old 08-15-2015, 11:20 PM   #20
Mike V. Florida
Glenn
When the generator is spinning it makes electricity. When you apply electricity to the generator it runs like a motor. To keep the generator from trying to run like a motor, and killing your battery, when the engine is not running that little round box on the generator "cuts out" the electricity from getting to the generator.
