Old 08-13-2015, 11:45 AM   #1
NeillB
NeillB's Avatar
Smile electrical fuse problem
I keep burning my main fuse I am using a 25amp fuse on my 1929 model A, I loose all my lights and horn I have checked all the grounds and power can not find anything the problem is intermittent it may last several trips or burn the first few minutes of driving,I have checked the the generator at an idle seems to be charging wondering if the charging system is not working correctly and over loading it a higher RPM. wonding if any has had this issue and could point me in the right direction to troubleshoot.
thanks
NeillB is offline   Reply With Quote
