Old 08-07-2015, 06:59 PM   #1
ericr
ericr's Avatar
Default what kind of grease gun are you using?
members have posted references within other contexts to this question, but it has never been a fuil-blown thread. So what type of gun are you using, no matter what your fittings are?
Some folks are using the little gun that came with the car but I am wondering if there is a better way. The original gun holds not-so-much lubricant and is somewhat of a pain to fill. Also apparently the gun was designed for some type of semi-liquid lubricant not in general use today, and not designed for mere cup grease or the like.
ericr is offline   Reply With Quote
Old 08-07-2015, 07:08 PM   #2
CarlG
CarlG's Avatar
Default Re: what kind of grease gun are you using?
Mine:
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-07-2015, 08:26 PM   #3
redmodelt
redmodelt's Avatar
Standard hand pump cartridge size gun. Change the tip or hose as needed.
Old 08-07-2015, 08:52 PM   #4
Redbird
Redbird's Avatar
I rebuilt and use the grease gun that came with the car. Loading the gun with regular chassis grease and a few pumps at each point is part of the fun of owning one of these things!
Redbird is offline   Reply With Quote
Old 08-07-2015, 08:55 PM   #5
RonC
RonC's Avatar
Originally Posted by [U
ericr[/U];1135122]members have posted references within other contexts to this question, but it has never been a fuil-blown thread. So what type of gun are you using, no matter what your fittings are?
Actually I think the opposite.
For wheel bearings, Ford specified an NLGI grade 4 grease in the 1932 Service Bulletins. This grease is firmer than the commonly used NLGI grade 2 multi-purpose grease most everyone uses today for wheel bearings. I believe the NLGI grade 4 was specified to reduce leakage. However today we use better seals allowing the use of thinner NLGI 2 grease which I believe is better for wheel bearings.
RonC is offline   Reply With Quote
Old 08-07-2015, 08:59 PM   #6
RonC
RonC's Avatar
This type of gun works good on a lot of the fittings.
Old 08-07-2015, 09:19 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
The Altemite 6B is the easiest and quickest to use, it only takes 1 hand ---just place tip on the fitting and push
the only drawback is that it has to be hand packed ---but a modern power gun can fill it too
Old 08-07-2015, 10:05 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I use my original tool kit grease gun for the Model A. I like a couple brands of older American made grease guns, but I looked on ebay a few weeks ago and the only known American made pistol type grease gun I could find was a Lincoln gun, and the price is $33 with shipping. A couple years ago I bought 2 guns from Menards when they went on sale for $10 each, but they leak grease and make a mess. You can guess where they were made.
Old 08-07-2015, 11:40 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Modern grease gun with the hose replaced by a threaded tube and the adapter for original fittings.
Old 08-08-2015, 01:32 AM   #10
hardtimes
hardtimes's Avatar
'better way', yes, IMO !
I purchased a vendor supplied adaptor for the end of hose on my pneumatic powered Sears grease gun. I can lube the 'old time' ford zerks and then replace the end with modern end and continue to lube any modern zerks in my Model A. I have a combination of both, and have a goal of making all zerks modern. Just my choice, eh
hardtimes is offline   Reply With Quote
Old 08-08-2015, 07:07 AM   #11
Mitch//pa
i have the same as gun that Carl posted and screw on the adapter for the zerks. it saves the forearm
Old 08-08-2015, 08:30 AM   #12
ericr
ericr's Avatar
are these still being made? I assume not, looking at the 'patina' on them.
Old 08-08-2015, 09:26 AM   #13
Kurt in NJ
Kurt in NJ's Avatar
I
I did see a "new" one at Hershey ---but it was out of the price range I was paying, they wanted 25$, and I had already bought 5 guns at about 2$ each, I have enough to last me, these were the garage mechanics type of gun, they were made in the modern type of fitting too
when looking at one check that the plunger is tight---not much wobble, and that the follower piston inside is not crumbling (some are cork)
Old 04-26-2021, 12:00 PM   #14
Nlbloch
Tom,
I’m looking to buy the small cartridges of grease that I have used for years in my hand grease gun. No one seems to carry them any longer — but maybe I’m not searching for the right thing. Can you tell me the type, or brand, or lubricant you use in your hand grease gun ? This is for the general lubricating of the grease fittings — not the water pump.
Nlbloch is offline   Reply With Quote
Old 04-26-2021, 12:08 PM   #15
Kurt in NJ
Kurt in NJ's Avatar
I recently got some small cartridges at tractor supply
Old 04-26-2021, 12:35 PM   #16
Ruth
I usually use my Lucas Mini Grease gun when under the car (except for the u-joint). It uses the 3 oz. grease cartridges. I use the Lucas 'Red & Tacky' grease.
File Type: jpg Screen Shot 2021-04-26 at 10.30.56 AM.jpg (10.4 KB, 32 views)
Ruth
Old 04-26-2021, 04:11 PM   #17
JKY
Lincoln pneumatic and Lucas Red and Tacky, except for the wheel bearing zerks and the water pump. With four A's in the family the air gun saves some time on the lube day production line.
JKY is offline   Reply With Quote
Old 04-26-2021, 07:35 PM   #18
TerryO
TerryO's Avatar
I bought a gun and grease at ACE.
TOB
TerryO is offline   Reply With Quote
