Old 07-31-2015, 11:31 AM   #1
SHEC
SHEC's Avatar
Default Need help - Identifying rear trunk/steel with side door access
Howdy -
Recently came across a '31 Tudor with a rear trunk that has access from the side door only. Obviously period correct handle, no brand markings, steel body with a slightly bowed top supported by bows of wood. Very cool package. The door is on the passenger side - thank you for safety!
Any ideas as to brand or rarity? Also when I checked the body number on the cross member - it starts with a "T", perhaps Canadian built at the Toronto plant.
# T27994. Not a dimple dash, standard Tudor in all appearance except the trunk and dual sidemounts.
The block number was not very legible but stamped without an "A" at the beginning - Canadian all around?
Any input much appreciated.
Thanks -
Be well -
SHEC
SHEC is offline   Reply With Quote
