Old 07-26-2015, 07:06 AM   #1
RobR'35
RobR'35's Avatar
Default 6 volt positive ground tachometer
I'm curious if there's been a 6V positive ground tach produced in the past and who the manufacturers were.Also if a reproduction of quality is made today?
RobR'35 is offline   Reply With Quote
Old 07-26-2015, 07:30 AM   #2
Blu Dice
Blu Dice's Avatar
Default Re: 6 volt positive ground tachometer
Google is your friend - there out there, but expensive.
4 doors are better than no doors!
Blu Dice is offline   Reply With Quote
Old 07-26-2015, 07:48 AM   #3
Planojc
Planojc's Avatar
I have Westach 6v Tach's on all my cars. http://www.westach.com/
Planojc is offline   Reply With Quote
Old 07-26-2015, 08:18 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Just curious to know if this is the Westach tachometer you are using?
Model: ***2CT54-6V
Price: *****$124.65*
Tachometer 5,000 RPM, 2" round, std pt ign, 4 imp/rev ( 8 cyl ), 6 volt, pos or neg grd
John
Old 07-26-2015, 08:30 AM   #5
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Back in the early 70's I had a 53 rag top 6 volt system, it had a Sunnen tach, it had about 6in. square box on the fire wall that went with the tach. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 07-26-2015, 08:54 AM   #6
Steves46
Steves46's Avatar
Model: ***2CT54-6V
Hi John.
That looks like the one I have in my 46; I really like having it for it keeps me in-check when I'm cruising on the freeway.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 07-26-2015, 12:08 PM   #7
JM 35 Sedan
Originally Posted by Steves46 View Post
Hi John.
RobR'35, sorry if I am hijacking your post a bit, but this may be good info for you also.
Hi Steve, thanks for the reply. Did you use one of Westach's accessory mounting brackets as pictured below?
John
Old 07-26-2015, 03:28 PM   #8
Mike in AZ
Mike in AZ's Avatar
As Walt said...Sun tach with 6V, 8 cylinder sender on the firewall....can shop epay and find the 5K football tach to mount on dash or steering column.....EB1a sender....then you have to find someone to convert the sender from the old battery to new battery....can get expensive......have fun....Mike
link to 6K tach.....http://www.ebay.com/itm/VINTAGE-SUN-...60a689&vxp=mtr
link to sender....http://www.ebay.com/itm/NOS-SUN-TACH...b09d93&vxp=mtr
Mike in AZ is offline   Reply With Quote
Old 07-26-2015, 04:33 PM   #9
flathead 53
Smile Re: 6 volt positive ground tachometer
Westach in calif ,got one for my 40 coupe,looks great works great , about $140.00 with the mounting cup.
flathead 53 is offline   Reply With Quote
Old 07-26-2015, 06:09 PM   #10
4dFord/SC
4dFord/SC's Avatar
I found this vintage Sun "Football" tach on eBay and had it converted to solid state by Williamson's Instruments.
4dFord/SC is offline   Reply With Quote
Old 07-26-2015, 06:09 PM   #11
Steves46
Steves46's Avatar
John, I used the cup for column mount and also ordered the light kit which comes with a green and red bulb so that you can choose which to use. Since my 46 gauges are red, I'm using red. One other thing I neglected to mention, if anyone orders a tach, be sure to ask them to place (what they refer to as "goop") on the circuitry. This helps prevent internal disconnects caused by vibration.
Old 07-26-2015, 08:02 PM   #12
tubman
tubman's Avatar
If anyone is interested, I am having a friend who is an electronics expert working on converting a 3 1/2" Sun-Pro tach to work on 6 Volts Positive ground. At the present time, we have it running and are now at the point of getting it properly calibrated. He tells me that the problem is that the signal from the distributor is -6 volts and the problem will be easy to overcome. When done, I will run the prototype on my '51 to check accuracy and durability. The Sun-Pro tachs come with black or white faces, and are not that bad looking. We expect to be able to make these in the $50 to $75 price range.
Stay tuned.
tubman is online now   Reply With Quote
Old 07-27-2015, 01:17 AM   #13
flatheadmurre
flatheadmurre's Avatar
Tubman what you need to make it work is basicly a counter chip go for the 555 its dead cheap.
Have a setting so the max output is for the gauge max readings...5k for example.
Then you need an op amp to drive the gauge just adjust the amplification so 5k input makes the gauge give a full reading.
With 2 adjustable resistors you have a board driving any tach out there sun or other...
Most chips would work on 5v.
A couple of bridge rectifiers at feed and input of the board makes it accept both positiv and negativ ground.
Add a voltage regulator and it accepts 6 or 12 volt.
Then use surfacemount components and it all fits and bolts to the back of the instrument inside the cup.
Old 07-27-2015, 05:30 AM   #14
mike42
mike42's Avatar
I bought the Westach 3 years ago and really like it. Great product and small enough to sit under the gauge cluster and mounted to steering column on my '40.
Mike
mike42 is offline   Reply With Quote
Old 07-27-2015, 05:32 AM   #15
russcc
Keep us posted. I believe there is huge market out there for some type of universal transmitter interface product for all the original tachs like Stewart Warner, Sun, etc. It could be remote mounted like the originals or inside the tach. The instrument guys do a good job of converting them, but it can take a long time for them to do it, and it's pretty pricey.
russcc is offline   Reply With Quote
Old 07-27-2015, 07:29 AM   #16
JM 35 Sedan
Mike
Thanks for the additional input on this. That's what I am going with.... placing an order today. I don't care about the coolness/nastalga factor of having an older/original tach, I just want something small, easy to mount, reasonably priced, that looks presentable and works well to accurately monitor engine RPM.
John
Old 07-27-2015, 08:16 AM   #17
Planojc
Planojc's Avatar
I like the bullet style case which mounts to your steering column. Also the 35K tach is all you need for a flathead.
Old 05-30-2018, 08:51 AM   #18
tubman
tubman's Avatar
I just ran across this thread again and to put a cap on things, my partner and I have finished this project. We have three ways to install a tachometer on 6 volt positive ground vehicles. Here is a pdf describing what we have available.
I am posting this now as I have one of our original production run type 1 driver box left to sell and would like to gauge any potential demand to see if we should gear up for another run.
Old 05-30-2018, 03:21 PM   #19
FireEngineMike
FireEngineMike's Avatar
Does anyone run the 6-volt pos ground Westach with a distributor mounted coil using the ballast resistor? I read that there is not enough voltage to run the tach.
FireEngineMike is offline   Reply With Quote
Old 05-30-2018, 03:39 PM   #20
flathead 53
I have A westach 0n my 53 ford f-100 6 volt pos ground ,and had one on my 40 coupe ,great tach ,good people to deal with.
