Old 07-21-2015, 03:07 PM   #1
sethkestenbaum
sethkestenbaum's Avatar
Default Correct fastener question with photos
I am trying to determine what is the correct pin/screw/? for this hole. I don't have my judging standards with me. Thoughts?
Seth Kestenbaum
www.oldcarroadtrip.com
sethkestenbaum is offline   Reply With Quote
Old 07-21-2015, 03:10 PM   #2
Mitch//pa
Default Re: Correct fastener question with photos
whats that a picture of?
Old 07-21-2015, 03:40 PM   #3
d.j. moordigian
d.j. moordigian's Avatar
A Cad plated collar with a rivet..
d.j. moordigian is offline   Reply With Quote
Old 07-21-2015, 04:29 PM   #4
sethkestenbaum
I've added a photo of the location on the bell housing. The open hole is on the passenger side. I didn't think that that side received a collar.
Seth Kestenbaum
Old 07-21-2015, 05:56 PM   #5
1931 flamingo
1931 flamingo's Avatar
Mitch and Seth: Looks like throwout brg shaft arm rh side of tranny??
Paul in CT
Old 07-21-2015, 06:22 PM   #6
Mitch//pa
Seth.
the shaft for the throw out bearing fork which you pictured the hole should be on the drivers side to accept the lever and pin.. here are some pics...
passenger side.
Old 07-21-2015, 06:22 PM   #7
Mitch//pa
drivers side
Old 07-21-2015, 06:36 PM   #8
d.j. moordigian
It has an early-28 clutch release shaft.....for a multi-disc bell housing. The end is long
for a collar with a rivet! You have a single plate bell housing....does this information
help?? Hope you have the correct T/O fork...
Dudley
Old 07-21-2015, 06:37 PM   #9
sethkestenbaum
Two more images to help in the trouble shoot. The car is an EARLY 29. Thoughts?
Seth Kestenbaum
Old 07-21-2015, 06:40 PM   #10
Mitch//pa
here is the pic i took off Seth's web site
Old 07-21-2015, 06:50 PM   #11
sethkestenbaum
here is a shot of the driver's side (as taken from under the car looking towards the back). It has a pin through it that appears flattened out on the bottom and has a head on the top.
Seth Kestenbaum
Old 07-21-2015, 07:09 PM   #12
d.j. moordigian
It's the same shafttill mid 29 !!
Wheres the old shaft?......the collar is still on the old one...
Old 07-21-2015, 07:48 PM   #13
sethkestenbaum
In looking at Mitch's image (passenger side posted 7:22PM) and at some photos of I took of the bellhousing removal months ago, this shaft did not protrude the bellhousing. There was no collar visible on the passenger side.
Seth Kestenbaum
Old 07-21-2015, 08:57 PM   #14
sethkestenbaum
WardAZ (and all), from the WardAZ photos I now understand what DJ was getting at. My concern now is that the shaft didnt previously protrude the housing. So the question is "what do I do or need to check next?" While my car is not a points car, I want it to be "correct" and safe. Thoughts? I would hate to have to pull the bell housing if adding a collar is "good enough".
Seth Kestenbaum
Old 07-21-2015, 10:55 PM   #15
Gary Karr
Gary Karr's Avatar
If your car is an early '29 with a single disc clutch, you have the wrong clutch release shaft. Yours should be flush on the right side and take the collar with pin on the left side.
Gary Karr is offline   Reply With Quote
Old 07-22-2015, 10:27 AM   #16
d.j. moordigian
The PPL shows that shaft for "1928 multi" only,...I thought it was carried
over longer. I just don't know..
Also, I don't remember seeing a collar and pin on the left side, at all?
Old 07-22-2015, 11:25 AM   #17
sethkestenbaum
DJ, I think you are correct (as several of the supply catalogs indicate that some single disc clutch cars in 1929 used the shaft. I'm still figuring out what is correct. I'll probably call around later today to figure this out. It is amazing what you learn when you dig. My concern now is about how "interchangeable" these shafts are. If this longer shaft works the same and has no downside, so be it.
Seth Kestenbaum
Old 07-22-2015, 11:58 AM   #18
d.j. moordigian
My thought....
The shaft was changed from a woodruff key and pin to just a pin when they changed
the T/O fork. That change shows up in the Service Bulletins in June of 29, page 351.
Gary is a 28-29 guy and knows them well,...I like to think I'm a 28-29 guy also.
I just question the shaft change(time line) and the collar on the left..
This, I think, would be a question for the JSC,....tho trivial?
Old 07-22-2015, 04:45 PM   #19
sethkestenbaum
As a follow up, the collar is part #A7616R according to what is reported to be in a parts catalog from the 1930s. I haven't found any new ones... I have found the location of some old ones. I still don't know if the shaft that was in the car when I got it or the shaft installed in the rebuild is correct. Hey, isn't killing 1/2 a day and loosing a night's sleep to figure out the details part of the fun (UGH!). I'm hoping to hear back from the guys at MAFCA.
Seth Kestenbaum
Old 07-22-2015, 09:09 PM   #20
Tom Wesenberg
Tom Wesenberg's Avatar
I don't recall ever seeing a single plate clutch shaft use a collar on the right side.
