#1 |
Just curious, at what clearances do rod and main bearings start to knock?
#2 |
I've seen [heard] them knock at .003" on other engines. These model A engines seem to be able to handle a little more before they get noisy.
#3 |
Depends on oil viscosity, too. And oil temperature.
#4 |
They put up a pretty good knock when the Babbitt in a rod decides to fall to the bottom of the pan in little bitty pieces.
#5 |
RE; 29 Business Coupe -my engine was rebuilt before I bought the project , when I finally got it together and running it had a knock, determined it sounded like it was # 2 cylinder. I pulled the pan rolled the engine over and was able to see the rod was tight against the piston Boss , just had to pull that piston and had the boss machined for clearance , good as new now. might not be your problem , just sharing my results
Any man who thinks he can be happy and prosperous by letting the Government take care of him, better take a closer look at the American Indian!" - Henry Ford |
#6 | |
most likely this means the rod is bent, and that the piston is cocked in the cylinder |
#7 |
Hi Kurt,
What would cause tods to bend? Regards Chris Cape Town |
#8 | |
![]() Quote:
#9 |
I've heard tell uf a "ROD BENDIN' GREMLIN"!--Sum times, he fills one cylinder clean full uf WATER & WHAMO!
Bill W.
#10 |
#11 |
Rod NOT Bent , machinist inspected , aftermarket piston problem
