Old 07-09-2015, 09:26 PM   #1
old guy rich
old guy rich's Avatar
Default Radiator cap
Hi guys, did some searching but didn't find what I was looking for. Can someone tell me the correct pressure radiator cap to use on my 50 Merc? Thank you, Rich
old guy rich is offline   Reply With Quote
Old 07-09-2015, 10:36 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Radiator cap
The Mercury Manual says that: The presure cap used on the cooling systems of the CM engine is the pressure regulator type. The pressure valve in the cap opens at approx. 3 1/4 psi to 4 1/4 psi on the 1949 and early 1950 Mercury CM engines. The late 1950 and all 1951 models are set to open and 6 to 8 psi. With this in mind I would go with the 7 pound cap. Make sure you pick the cap that fits your radiator neck. Check out the various caps and vendors here:
https://www.google.com/webhp?sourcei...radiator%20cap You might be able to get one at NAPA.
Old 07-10-2015, 07:36 AM   #3
billfish
billfish's Avatar
Would Ford be different than Merc, Ford shop manual calls for 3 1/2 to 4 1/2 cap on all 6 and 8 cyl cars except cars equipped with fordomatic trans.
billfish is offline   Reply With Quote
Old 07-10-2015, 09:29 AM   #4
G.M.
The temperature of the engine determines the required pressure cap. If the engine runs below 210 degrees the pressure cap will NEVER open from engine temperature. The only thing that would open the 4 lb pressure cap below 210 degrees would be a compression leak into the cooling system. The pressure in the system below 210 is less than 3 lbs. Forget the term "raising the boiling point" it has no meaning in our old Fords. If they run over 210 there is a problem that needs fixing. G.M.
www.fordcollector.com
Old 07-10-2015, 10:38 AM   #5
old guy rich
Thank you 19 Fordy and G.M. I'll get one today. Rich
