#1 |
I just put the clutch and trans on my 292 y-block with a Craiger bell housing. Everything went together smoothly but once I got it into the chassis and hooked up the linkage it is not depressing the 3 clutch arms. I can see through the inspection hole that the throw out bearing slides ahead but when it comes into contact with the 3 arms movement is stopped. I pushed the clutch pedal in with my leg but stopped when I felt I was going to break something.
Thought? Thanks in advance for the help. Z |
#2 |
What chassis, what linkage, what clutch, where are the pictures, stock parts, modified parts, gyp chinese parts---etc
It's hard to give advice on non stock modifications without knowing all the modifications and parts used Last edited by Kurt in NJ; 07-06-2015 at 11:08 PM. |
#3 |
You could remove the linage and try to operate it by hand 39 lever or 40 style shaft.
#4 |
It might be something to do with the centrifugal weights fouling the bellhousing adaptor. If it is an 11" clutch or a 10", this could be the problem. At least it needs eliminating first if it is something else.
Mart. |
#5 |
The y block has a smaller shaft and the big throw-out bearing maybe hitting the pressure plate.
#6 |
#7 |
Y block truck has the same 1-3/8 input and a guess if your putting this in a early ford you have the truck timing cover and oil pan on the motor with a hurst motor mount?
#8 |
With the pedal linkage disconnected the pedal moves nicely with the return spring tension. Pushing the lever on the trans brings the throw out bearing up to the 3 clutch arms but that is where it stops.
Yes, the Y-block is a truck for the oil pan and fan clearance. I will try to get some pictures of the clutch tomorrw. Thanks for the help thus far. |
#9 |
Opened the trans back up and just the spring on the throwout was caught. Reinstalled and working ? Always the little things that cause setbacks.
Thanks again for the responses. |
