#1 |
need help finding parts break down - parts list - break down ... for a ford magneto (air plane & stationary) 1930's wico jem 1509. thanks .. steve
V4f Last edited by V4F; 07-07-2015 at 09:01 AM. |
#2 |
Try one of the racing magneto service companies like
Tom Cirello Don Zig Joe Hunt. |
#3 |
#4 |
found a good place for parts , just need a diagram for reference
good link ... thanks
V4f |
#5 |
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
#6 |
Rudy Calin www.rebuiltmags.com 651-233-6655 **********
V4f Last edited by V4F; 07-05-2015 at 02:32 PM. |
#7 | |
![]() Quote:
These 'up top' mags that fit A/B Ford 4 cyl engines, have a tendency of work loose and they have more resistence/wear on cam gear due to impulse mech operation. I've had a few of that type mag. Have you considered the 'side drive' mag for such engine ? |
#8 |
no I haven't , but I like the ford mag . ill try it for awhile & see . do you know of a parts catalogue for the jem 1590 ? thank you .. steve
V4f |
#9 | |
![]() Quote:
I'm thinking that you have a Wico jem 1509, rather than a 1590, eh ? |
#10 | |
![]() Quote:
#11 |
#12 |
yes mine is a "1509" . I miss printed . found out they are very rare . not made since 1943 . a collectors item maybe ? LOL
V4f |
#13 | |
![]() Quote:
#14 |
apparently the have a "lag angle" . at start they are retarded 9-12* . soon as it starts it is back to where you set it . mine has that . if I get it together & in I will let you know how I like it .......... steve
V4f |
#15 |
I just picked up a 1509 for my banger...anyone using one on their car?
#16 |
Just a comment, I agree with hardtimes about it may not be a good idea to run a top-drive mag, especially while up in the air. If it slips or jumps time you could be stuck up there all day waiting for a tow! It would be especially likely to be a problem with the impulse still in the mag, it would put a lot of strain on that little drive gear. I run a side-driven mag in my Bonneville engine without an impulse, and it fires up with no problem.
#17 |
Jim,
you may want to discuss removing the impulse mechanism and talk about starting the motor. John
As Carroll Smith wrote; All Failures are Human in Origin. |
#18 |
Here is a freeby. https://oldcroak.com/jem-manual/
Parts are not easy to get for the older Wico Jems. Most of the Pietenpol aircraft that used the model A engine ran an crankshaft driven magneto that was more conventional is design. The Pietenpol kit for the engine used a special head for cooling so they moved the mag. An impulse coupling was built in to the Jem 1509 for starting. There is no other provision for a starting aid unless the mag body can be rotated and connected to the spark control in some way. Starting at full advance will eventually damage the starter due to kick back. |
#19 |
John, The mag must be partially disassembled to remove the impulse, it looks similar to advance weights. In our lakester we use a starter off a Toyota or something, but I also have run that engine on the street using a stock Model A starter running on 12v. In both cases the engine starts right up, no problems. I engage the starter and when the engine is spinning, I flip the ignition switch to 'on'. I'm running 35 degrees advance, it has never kicked back or failed to start. Simple, like me!
#20 |
Yes, Thanks Jim,
The impulse mechanism I am told was to assist in starting airplanes. Not to retard the timing, but to give a quick snap of the mag to actually make spark. And for what its worth, not having to disassemble something to improve it seems like cheating. After all, having left over parts is the whole idea! John
