#1 |
Does anyone have the part numbers for replacement sealed beams. I don't want to blow a head gasket at O'reillys. No I dont have powersteering!
#2 |
FOR WHAT????two light-4 light - round square size???
sylvania 6006 6 volt is under $10.00 if that is what you are looking for Ok I see you need 12 volt probably less for them |
#3 |
Please read my title. 1940 Ford headlights. They are of course round. And now 12 volt. Thanks in advance.
#4 |
6012 was the number in the old days. Maybe still available. Also try 6014, and 6024 which I believe are halogens. DD
#5 |
Yes, get the 7" round 12V. Halogen sealed beam H6024
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I put my rear-end in the recliner, and now I'm going to rest up & watch TV. ![]() |
#6 |
#7 | |
![]() Quote:
------------------------------------------------------------------ The 6012 is 50/40 watts High/low beam. The 6014 is 60/50 watts high/low beam. The 6012 is difficult to find any more. The 6014 was used as a replacement for the 6012 over the years and can still be found. The H6024 is the Halogen replacement for the 6014 and is rated at 65/35 watts. |
#8 |
The manager at napa told me. Not the internet
#9 |
Just bought a pair when I converted my p/u to 12 volts. My local parts store had them in stock. Any good parts supplier should have them.
Making the simple complicated for over 30 years. |
#10 |
Thanks to everyone with positive input.
