Old 06-28-2015, 03:24 AM   #1
bluedog
bluedog's Avatar
Default stuck diff plug
I am having trouble getting the diff fill plug out. It simply won't budge at all. I have only had the car 12 months and am keen to check on the oil level. Is there any risk of breaking anything if I use more force?
Greg
bluedog is offline   Reply With Quote
Old 06-28-2015, 03:38 AM   #2
RUNNERBUN
RUNNERBUN's Avatar
Default Re: stuck diff plug
No, you.re not likely to break anything. Just use the longest lever or extention on your removal tool, It will give. Just make sure that your driver has a good snug fit in the fill plug. Good luck.
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 06-28-2015, 03:53 AM   #3
colin1928
colin1928's Avatar
As Runnerbun said the main thing is a good fit with tool to the plug
you can also heat round the plug a little just go easy with the heating
colin1928 is offline   Reply With Quote
Old 06-28-2015, 05:13 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Times 3 on the good tight fit.
Old 06-28-2015, 07:43 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
If some of the threads stick out, just put a serious ding on the side with a center punch, then angle the punch & rap it HARD, to break it loose.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-28-2015, 08:04 AM   #6
Big hammer
A hand impact driver with a tight fitting adaptor? A of course use a Big Hammer :-) times 2 like what Bill said
Old 06-28-2015, 08:11 AM   #7
Y-Blockhead
Y-Blockhead's Avatar
Yes, A hand impact driver (not a pneumatic impact), a tool that is often overlooked but usually works.
Old 06-28-2015, 08:48 AM   #8
BILL WILLIAMSON
B.H,
My most commonly used hammer is a 48 Oz Ball Pein, with a 2/3 length handle, for BETTER control
Bill Hammer
Old 06-28-2015, 08:57 AM   #9
Mitch//pa
once u go dead blow youll never look back
Old 06-28-2015, 09:01 AM   #10
Ray in La Mesa
If the hole is rounded out, you can take an old Vw wheel stud, grind it to a tight fit then use a socket and the hand impact wrench.
Ray in La Mesa is offline   Reply With Quote
Old 06-28-2015, 12:19 PM   #11
J Franklin
J Franklin's Avatar
Don't forget to apply some penetrating oil the day before.
Old 06-28-2015, 12:21 PM   #12
BILL WILLIAMSON
Bro Mitch, Bro Dog heer,
Duz thet meen Dad wuld hit himself in the haid & NEVER look the SAME agin? Or never be able to look back agin? NOW, you got me worried On COLD nights, I NEED him!
Buster T.
Old 06-28-2015, 03:06 PM   #13
Larry Jenkins
Two things..
One, make sure you have dug out all the dirt and grime from the 3/8" square hole in the plug. All the way to the bottom.
Then, using a 3/8" drive socket wrench with a long extension, the plug will probably come out.
Did just this on mine a couple days ago.
Larry Jenkins
Larry Jenkins is offline   Reply With Quote
Old 06-28-2015, 05:54 PM   #14
d.
Default Re: stuck diff plug/ get it clean
yes to thoroughly cleaning out the plug...use your dental picks or whatever, but get it clean, side to side and top to bottom.
I have used an impact wrench basically set to off (very, very low) and just let it chatter away until it spins out.
The acetone/ ATF mix might help loosen things for you also.
d. is offline   Reply With Quote
Old 06-28-2015, 08:52 PM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
3/8" square drive will often work, but the correct size should be 7/16", so try to find a piece of 7/16" square shaft, or a 7/16" square head bolt, then weld a T handle to the bolt head.
Old 06-28-2015, 09:27 PM   #16
29 model-a
29 model-a's Avatar
Couldn't you double nut two 7/16 nuts on a bolt and use that?
29 model-a is offline   Reply With Quote
Old 06-28-2015, 10:14 PM   #17
Tom Wesenberg
Yes, it's worth a try. I used a 7/16" square head bolt and clamped onto it with a Vice Grip when I didn't have my correct tool with me.
