#1 |
I'm thinking of casting an aluminum block to see how one of those castings would look also. What would be the guess as to people wanting aluminum?
I have molds and cores, so why not try one? Tod |
#2 |
I'd increase the center main web thickness for more strength if you haven't already thought about that.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#3 |
#4 |
Provision for oil galleys for full pressure oiling?
#5 |
#6 |
#7 |
Any "guestimate" as to w-h-e-n you might have a block done for one of us candidates just sitting impatiently in the wings...........
#8 |
Tod, what is the shrinkage difference between aluminum vs. cast iron?
#9 | |
![]() Quote:
I have a guy who will take the first couple, so I'm not going to talk about it anymore. I have an iron one machining right now, first, though. But, paying work comes first, always. Tod |
#10 |
I would be interested in a block with 5 mains, full pressure oiling, and larger insert bearings.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
#11 | |
![]() Quote:
Yup , aluminum sounds pretty good to me also, but with FIVE mains for crank and FIVE bearings for cam. If you find it easier to do than to get after the iron casting same configuration, then I'll flip my deposits over to that style (aluminum) block ! -Can you say if YOU will install the iron sleeves ? -does cam bearing surfaces in alum , need bronze bushed ? -Can you say what might be cost difference between alum/cast iron blocks ? Lastly, you haven't given up on the 5x5 B style iron block, eh ? |
#12 | |
![]() Quote:
Email me. I have not given up or stopped on anything. All my suppliers seem busier than normal and are dragging things out waaaay further than expected and beyond what they told me. So, I keep plugging away as best I can. I will install cylinder sleeves. I think cost will be close to the same, but I won't know for sure until I cast one. |
