#1 |
I have not had the drums off this little roadster for at least 5 years. Every year someone tests these brakes to the limit. This morning was one such day. A dumb@#@% woman pulled right out in front of me this morning and I locked up all 4 and came to a tire screeching halt and we missed by 2 feet. She just kept right on going without even a glance, oblivious.
There are some that like to say these brakes don't work. They do ! |
#2 |
When they are done right, they do work very well. Sorry yours got put to the test!
#3 |
You need a paint gun mounted to hit the side or back of their car. Leave them a little memento of their stupidity.
#4 |
#5 |
she was to busy texting to worry about u
#6 |
Terry |
#7 |
I think the effectiveness is directly proportional to the panic level when applied! Ron W
#8 |
I spent the time and money last fall to upgrade to cast iron drums from Brattons and complete overhaul of the rest of the system and yes they work great. Moo
#9 |
With hydraulic brakes, you'd have missed her by 4 feet
#10 |
Kahuna, once all four tires are sliding, having hydraulics or mechanicals makes no difference. What would make a difference would be wider tires. If you could lock up all four 6:00X16 tires with mechanical brakes, he may have missed her by 5 or 6 feet! Or, if one had the presence of mind to modulate the brake pedal to stay just shy of lockup, maybe miss her by 7 or 8 feet.
#11 |
I like the paint gun idea. Maybe I will keep one in my Honda as well. I encounter so many stupid drivers since I drive at least 1000 miles per week.
#12 |
#13 | |
![]() Quote:
![]() After we exchanged names etc, he said he worked for Holden (GM cars here). I suspect his life is so wrapped up in new cars that he just didn't recognise what he saw as a car. I locked up the wheels that day but there was no screeching, only a not very loud scraping sound. I prefer screech so the other idiot gets a fright. ![]()
#14 |
Often been said.. Properly adjusted Model A mechanical brakes are superior to hydraulics.
Any one who has thoroughly gone through Model A mechanicals knows that. Larry |
#15 | |
![]() Quote:
Have you thoroughly gone through Model A mechanical brakes yourself or are you repeating what you've heard on this forum Why is it that new car manufacturers don't know that mechanical brakes are superior to hydraulics? Seems as though they replaced mechanicals with hydraulics. Were they wrong? Bill ps. If you really think mechanicals are better than hydraulics, You've got a lot to learn. |
#16 |
When people lose their license for txting and driving like a DUI, it will stop fast.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
#17 | |
![]() Quote:
plus most hydraulic brakes are self adjusting, people can barely handle changing their oil when their supposed to nowadays and greasing ball joints is unheard of. How many of you can honestly say you grease your ball joints every oil change? Tie rods? steering linkages? Couldn't imagine being on the road now with brakes you must manually adjust! But for a model A when your comparing drum to drum brakes, you arent gaining anything (if anything your loosing) safety by switching to hyd. Are the hyd people are installing a split system? If not then gimme mechanical brakes anyday!
1929 Model AA - Need long splash aprons! |
#18 | |
![]() Quote:
Yes I have. Just completed a total restoration on all four brakes. For the third time on 3 Model As over the years. As far as to why modern iron are all hydraulics, it's mostly about cost. On my second Model A, a 1930 Coupe, I designed and built hydraulic brake system. Worked OK, but I prefer well done mechanicals. |
#19 |
"If you could lock up all four 6:00X16 tires with mechanical brakes, he may have missed her by 5 or 6 feet!"
That's a wider tyre with a smaller diameter which will have a shorter, but wider, contact patch than say a 450 x 21. Does the 16 inch wheel grip better? |
#20 |
updraught, I'm too lazy to look up specs right now but there's not a big difference in overall diameter between a 4.50x21 tire and a 6.00x16 tire, but there is a noticeable difference in width. So in my opinion the wider tire will grip better.
