Old 06-20-2015, 02:07 PM   #1
pgerhardt
pgerhardt's Avatar
Default Worst idea since New Coke!
Don't get me wrong. I think Rust-oleum makes good paint that I use it on both home projects and some model A parts, but the guy who decided to change to the new design nozzle should be fired! The only thing the new Rust-oleum nozzle does is guarantee that it WILL clog and be impossible to clean and WILL leak all over your hand and maybe your work!
So Rust-oleum, please ditch the "new nozzle" and give us your product with standard nozzles that we can remove, clean and replace if needed!!!
pgerhardt is offline   Reply With Quote
Old 06-20-2015, 02:54 PM   #2
mshmodela
mshmodela's Avatar
Default Re: Worst idea since New Coke!
I moved on to Dr. Pepper after 30 years as a Coke Drinker..
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 06-20-2015, 05:57 PM   #3
jbond
amen I quit buying for now.
jbond is offline   Reply With Quote
Old 06-20-2015, 06:05 PM   #4
Spokes
Rust-oleum make a nice trigger and handle that slides over the top of their spray can works Great
Spokes is offline   Reply With Quote
Old 06-20-2015, 06:12 PM   #5
SeaSlugs
SeaSlugs's Avatar
i can still find the regular style rustoleum everywhere by me...(walmart, menards, lowes, ace, etc)
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 06-20-2015, 06:17 PM   #6
jkassay
jkassay's Avatar
+1 on the mess created by that nozzle. Bought several cans thinking it was just a bad can. They are all the same. And when they start splattering it messes up the paint job. Not using them any more.
jkassay is offline   Reply With Quote
Old 06-20-2015, 09:01 PM   #7
scrapiron
Their best nozzle was the OLD style little red one,,,IMO
scrapiron is offline   Reply With Quote
Old 06-20-2015, 11:23 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
If they have a phone number on the can, be sure to call and complain. I've also made a mess trying to use the new nozzle. I wish when something works well they would just leave it alone. You hear that Microsoft?????
Old 06-21-2015, 10:36 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
Use Krylon instead!
Bob Bidonde
Old 06-21-2015, 12:06 PM   #10
C26Pinelake
I can still get the old style and bought it as late as yesterday. Wayne
C26Pinelake is offline   Reply With Quote
Old 06-22-2015, 01:12 PM   #11
pgerhardt
pgerhardt's Avatar
I contacted the Rust-oeum people about their crappy nozzles and got this reply:
"Hi Paul,
Thank you for contacting Rust-Oleum Product Support.
We are sorry to hear of the problems that you are having with our Universal cans. Occasionally, pieces of pigment can settle down at the bottom of the spray can. Inside the can is a dip tube that pulls the paint from the bottom of the can to the tip. If the pigment in the paint is too big or if there’s not enough pressure behind it, it can get stuck in the tube or tip and the paint wont spray. If the clog is in the tip, wiping it with mineral spirits should clear it out; if the clog is the tube, there is unfortunately no way to clear it. Keeping the nozzle clean, by wiping off with a rag after each use should help keep it from clogging with dried paint.
If you can provide the product and batch codes from the underside of the can(s) we can look into this further. We would also be happy to issue a refund for the product. Attached is a photo identifying the product and batch codes from our can. Please note that these may vary slightly in placement / location on the can itself.
Sincerely,
Corinna
We have registered your complaint in our database. Please refer to the File Number in the Subject line of this e-mail for any future reference to this complaint. "
I sent them the picture they requested along with one of the mess the nozzle created. So we will see. . . But I also ordered Krylon from Amazon to give it a try!
Old 06-23-2015, 04:36 PM   #12
26Tguy
26Tguy's Avatar
I agree completely! I have found wiping it as soon as I'm finished using it does help... but not 100%.
Have you tried Krylon recently? LOVE the nozzle and spray pattern!!! Waaaay better than Rustoleum.
26Tguy is offline   Reply With Quote
Old 06-25-2015, 05:06 PM   #13
pgerhardt
pgerhardt's Avatar
I got another email from Rust-oleum asking me for details about problems I had with their nozzle. This is what emailed back:
The new nozzle design is unnecessarily complex with a long path for the paint to travel before spraying, and doesn’t improve the spraying experience significantly over a regular nozzle. When a clog occurs there is no way to remove and clean/replace the new nozzle and the can even if mostly full must be thrown out. In addition on a number of occasions a failure of the new nozzle inside the cap has resulted in paint dripping out all over my hand and work! I Just can’t trust this new design to provide consistant performance. Until Rust-oeum conforms to the “KISS” (keep it simple stupid) engineering principle and returns to industry standard nozzles, I’ll be using Krylon.:
Old 06-25-2015, 05:29 PM   #14
C26Pinelake
The. Big problem is they don't care ! You are one of millions of customers and they could not care less. Likely the person that contacted you is a contractor with no vested interest ! Wayne
