#1 |
I just purchased a 1931 Deluxe Roadster and I'm having trouble attaching the top to the stantions. It seems as if the canvas top has had some shrinkage. I have a 1931 Cabriolet which is starting to experience the same problem. My 29 Roadster with a vinyl top never is a problem. Do these canvas tops experience shrinkage and is there a remedy?
Thanks for any advice. |
#2 |
I can't help with the shrinkage, but was told many years ago to never store covertibles with the top down. I do know they shrink some, because some original side curtains no longer will fit my 28 Phaeton.
#3 |
they are a tight fit sometimes. I would park it in the sun with the top up but not forced to go into the sockets then after a short while they should slip in place. I never stored mine with the top down unless it was just over night.
#4 |
I don't think shrinkage is the problem. The canvas is not going to compress that oak header. I filed a small chamfer on the sharp vertical edge of the top bracket so I could slide the brkt in from the front or back, and not try to go straight down with it over the post. For some reason, I think the windshield wants to expand and cause this problem.
#5 |
I dont know about tops, but I was just swimming in some cold water....
#6 |
#7 |
Wet the top and put it up again in sunlight on a hot day will work best.
I leave my Cabriolet down 12 months and it still fits when I am caught in a storm. |
#8 |
Thanks guys!
