#1 |
Hi,
Can anyone try to describe: 1. How much engine oil consumption is normal in volume pr mile? 2. What is the maximum oil consumption before the engine needs an overhaul? 3. How much oil dripping is acceptable on the workshop floor after a drive? Would be interested in both diff, gearbox and engine itself. Lucas |
#2 |
/1. None. Oil consumption should not be noticeable in the interval between oil changes.
2. That is tough to answer. When my Tudor needed an overhaul, it wasn't using any oil, but the oil got dirty quick, and there was a lot of blowby coming from the oil filler tube. The final straw was the head gasket allowing coolant to leak into the cylinders and into the oil pan. 3. Again, that will vary. My rebuilt engine doesn't leak oil, but I do get an occasional drip of tranny fluid from the clutch housing where that hole with the cotter pin is in the bottom. Maybe 1-2 drops after a long drive. That is easily eliminated with the tranny shift rail seals available from the various suppliers. I chose not to use them because my tudor is a sorta blue-ribbon level car. Your differential should not leak at all. |
#3 |
When you see a blue cloud following your every turn, it is at least time to do a re-ring job.
#4 |
You're good to go until the oil runs out faster than you can pour it in! Back when an A was just an old car, poor folks would beg used drain oil from gas stations and keep pouring it in.
#5 | |
![]() Quote:
Bill W.
#6 |
#7 |
Back in the day, I always heard that it was cheaper to buy bulk oil in gallon cans than to do an overhaul on a Chevy!
#8 |
buy a brand new car and ask the service dept what the allowable oil consumption quart per miles is... youll find out its approx 800 miles per quart is considered normal give or take
#9 |
If you can even measure it in "volume per mile", that's a lot. Like was mentioned, a lot of people keep track of how low it is when they are ready to change it....but that distance varies with the owner too.
Most of them will leak a bit if they have much wear on them, but even though its a mess on the driveway or floor, it usually doesnt add up to much. When its a smoker, or you have to pull in the gas station and say " Fill er up with oil and check the gas", its about time. ![]() Good Luck |
#10 |
I had a 63 Ranchero, the oil light would come on and the oil pressure gauge would drop to about 10 lbs. I would pull over and dump 3 qts in it. that was after about 100 miles,
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
#11 |
Years ago I had an old 6 cylinder that burned so much oil I would stop at a gas station and told then to fill up the oil and check the gas.
#12 |
Back in high school I had a 1949 Plymouth for a few months and would buy a quart of bulk oil for 10 cents to add each time I bought 3 gallons of gas. The first Studebaker I bought used 1 quart of oil each 100 miles. I'll be overhauling the engine when I get around to it. I can live with a quart per 1000 miles, but I'd ring an engine that used more than that.
#13 |
I've run 3.0 liter V-6 Fords for years, changed oil every 5,000 miles and none of them were EVER down more than half a quart. In 5,000 miles.
Father -in-law traded for a Chevy pickup in 1986, after driving Fords for many many years. Thought he'd try something else. After he had the truck about a year, he made a round trip from northern Illinois to eastern Tennessee and used 7 qts of oil total, and this was a brand new truck. It never changed. Always sucked oil never leaked had to be burning it off. Chevy dealer told him 'oh, that's normal'. BS. He said 'If that's normal I don't want this GD thing' and went back to Ford and never looked back!! A quart every 800 or 1,000 miles seems pretty excessive to me ![]() |
#14 |
[QUOTE=BlueSunoco;1105234]I've run 3.0 liter V-6 Fords for years, changed oil every 5,000 miles and none of them were EVER down more than half a quart. In 5,000 miles.
Father -in-law traded for a Chevy pickup in 1986, after driving Fords for many many years. Thought he'd try something else. After he had the truck about a year, he made a round trip from northern Illinois to eastern Tennessee and used 7 qts of oil total, and this was a brand new truck. It never changed. Always sucked oil never leaked had to be burning it off. Chevy dealer told him 'oh, that's normal'. BS. He said 'If that's normal I don't want this GD thing' and went back to Ford and never looked back!! A quart every 800 or 1,000 miles seems pretty excessive to me ![]() it is but thats is the manufactures out to not have to do warranty work... we have customers burning oil on newer cars all the time. had a 2012 equinox in yesterday burns 1 qt to 1000 miles dealer told him its normal.. |
#15 |
Rule of Thumb I was taught was 1 qt of oil between a oil change.
John Poole |
#16 |
Now that really depends on how frequently you change you oil.
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
#17 |
Some manufacturers (GM is one, I believe) have a formula for allowable oil consumption based on fuel mileage! The more gas you burn, the more oil you can burn before they will do any warranty work. If I remember, allowable oil usage gets down to the 500 miles per quart range.
#18 |
Comparing oil consumption of model a's to modern cars is a little bit of an apples to oranges thing. Modern cars use a light multigrade oil such as 5-20w which will in fact get "consumed" faster than the oils we typically use in our 85 year old cars.
#19 | |
![]() Quote:
1. None ( well dependent on lots of things ; condition of engine and mileage driven). My '30 doesn't 'use' up any between changes as it is new engine with only 1500 mi., and how well engine break in was accomplished..example, my '04 used up a qt every 1000 mi when new, now 5000 mi and maybe one qt..go figure. 2. Depends on condition of engine, i.e.- more ..the more worn out an engine is vs none or very little for new engine. 3. None is acceptable and none can be accomplished when and if enough care and $ is spent to accomplish this goal. Last edited by hardtimes; 06-18-2015 at 02:12 PM. Reason: ......... |
#20 |
I have a bit of oil dripping from the lower part of the flywheel housing (where the cotter pin is situated). 2 questions:
1. If oil is dripping from that place, isn't there a risk that oil comes in contact with the clutch ... and then you cannot drive anymore? 2. How do you know that the babbit bearings need an overhaul? I suppose that the dripping oil passes by the babbit bearing. Lucas |
