#1 |
Please don't laugh to much as this rather simple question that an old guy is to lazy to find out for himself.
If a person sets the timing for one Model A engine, can you take that distributor and use it in another Model A engine and have it in time? I know a simple question that everyone knows but me and I am to lazy to move one distributor from one of my A's to the other to get my answer. Thus I don't mind embarrassing myself and ask you all.
Fred Kroon 1929 Std Coupe 1929 Huckster |
#2 |
It could be possible if the oil pump drive gear is indexed the same ---and the gear teeth of the cam and drive gear are machined the same, but the answer is NO
#3 |
Thanks guys, guess I should not be so lazy and get to work and get that other distributor timed for my huckster.
#4 |
Also what are the chances the other vehicles #1 cylinder is exactly at top dead center when you do drop in the timed distributor. So it's definitely a no to that question.
#5 |
This could be a Ford Barn FIRST!----- EVERYONE AGREED!!!
Bill W.
#6 |
#7 |
Happy to be of service to the old Barn!
#8 | |
![]() Quote:
my set up does not have the spring shown above the distributor string- Am I missing something? |
#9 |
I think it is inside your valve cover.
#10 |
Thanks - I neglected to think about the access location of the spring.
#11 |
Ok to add more to this simple question.......you can use any distributer body with any engine, yes?
In other words no drive gears are changed from the engines. |
#12 |
I think this is correct. But some of the other guys that know more about this than I do may give you more info on it.
#13 | |
![]() Quote:
It has NO SPRING on the drive gear housing. It seems to be staked/secured somehow??? I put one on! ALSO, the oil pump locating dowel was PEENED over & the oil pump DIDN'T fall out, AFTER I went to ALL the work to make up a ZIPPY retainer!!! "MAYBE" this was a common practice by rebuilders, WAY BACK THEN??? When I get Vermin DRIVING, I'll go by the builder & check on the EXTENDED WARRANTY ![]() ![]() BILL W.
