#1 |
Next project on car is to drain and clean fuel tank - what is the capacity? Any tips for draining - like what did you use to catch fuel as you drained it.
Thanks - 30-9 1939, 1940 |
#2 |
I believe my 39 deluxe 2 door sedan has a 14 gallon tank. Jon L.
#3 |
I'd be curious to know just how difficult it is to remove the fuel tank. I had no trouble removing the drain plug on mine and there was very little fuel left in it. Now I can feel a layer of grime on the inside bottom of the tank and I suspect the only way to clean it is to remove the tank.
https://www.youtube.com/user/roosty6/videos |
#4 |
Try to remove the drain plug but if it doesn't come out forget it. Pump out the tank as much as possible (cheep hand pump at Harbor Freight into a gas can) and remove tank.
#5 | |
![]() Quote:
to the drivers side. get a couple of LARGE screw divers and work them up between the top flange of the passenger side of the tank and the top frame rail and pry the tank towards the passenger side. Some tanks only have to move less than 1/16" and some an 1/8". Once the frame clears the top rail the tank flange will drop and clear the bottom rail. Reverse the procedure putting it back up but take a small piece of wood in the deep part of the frame with 2 pieces of 16 gauge metal against the wood and the top edge of the frame and the tank flange will slide up the 16 gauge and over the top flange. Find a new lead washer for the filler pipe seal. I dip the washer in fuel tank sealer before installing to seal it good. G.M.
www.fordcollector.com |
#6 |
#7 |
Musta been big azz tires but I like the idea 2
#8 | |
![]() Quote:
#9 | |
![]() Quote:
The tires were 14 inch I think. Worked good. |
#10 |
You should be able to remove it in less than a 1/2 hour. G.M.
#11 |
If I can do the job in half a day I will consider myself fortunate. Although this rusty relic from the Mercury came out in under an hour which simply amazed me. It won't be going back in though. :-(
