Old 06-13-2015, 12:57 PM   #1
Kube
Kube's Avatar
Default Date coding (etching) glass "bugs"
I'd just completed date coding (acid etching) ten pieces of glass for a 1940 Ford project I am working on. The entire process took less than one hour.
Each and every "bug" appears perfect.
I am very pleased and would like to suggest that anyone thinking of doing this, need not be apprehensive.
This particular kit was purchased from Mike Driskell of Third generation Automotive.
Without question, it was the easiest kit to utilize.
You can contact Mike (great guy) at 615-293-9985.
Mike "Kube" Kubarth
Old 06-14-2015, 09:48 AM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Date coding (etching) glass "bugs"
Thanks for sharing that information. I'm gonna give it a try on my Zephyr.
Ken/Alabama is offline   Reply With Quote
Old 06-14-2015, 10:47 AM   #3
oldford2
oldford2's Avatar
Kube,
Can this be done with the glass in place (vertical surface) or is it done with the glass flat? Thanks
John
oldford2 is offline   Reply With Quote
Old 06-14-2015, 11:04 AM   #4
35fordtn
35fordtn's Avatar
Mike,
Thanks for the mention. The etching can be done with the glass in or out of the car.
35fordtn is offline   Reply With Quote
Old 06-14-2015, 12:39 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
I've heard NOTHING BUT praise about Mike Driskell's products, service and the way he conducts business. His glass bugs sound like a great product. Coming from KUBE, that should mean something positive. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-14-2015, 04:09 PM   #6
Cecil/WV
Cecil/WV's Avatar
Does the etching chemical lose its strength?? I bought a kit from Nacewiez a few years ago and it worked great, but I tried again last fall and it wouldn't etch. All I need is the chemical.
Cecil/WV is offline   Reply With Quote
Old 06-14-2015, 05:21 PM   #7
35fordtn
35fordtn's Avatar
Cecil,
The etching chemical has around a one year shelf life if stored properly. The chemicals, and stencils we are selling are different from what Roy was selling but the etching chemical will store work with his stencils. If you need any of the chemicals give me a call 1-844-327-5988
Old 06-14-2015, 05:32 PM   #8
VeryTangled
VeryTangled's Avatar
Hi Michael, Thanks for your help to us hobbyists!
Just out of curiosity (I also have a kit that is a few years old, like Cecil), can you tell or show us what your kit looks like? Are the stencils different in some way?
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 06-14-2015, 08:41 PM   #9
35fordtn
35fordtn's Avatar
The stencils we sell now are a higher resolution than previous methods. The only draw back is that they are a single time use stencil. We went this route for MANY reasons. Since they are a single time use we send out 12 stencils in each kit (unless you have a station wagon or Model A), so that there are extras to practice with.
Old 06-14-2015, 08:52 PM   #10
swoopNZ
MEMBER EMERITUS
Mike,
How much is a kit to do one 39 coupe ?
Thanks,
Chris.NZ.
swoopNZ is offline   Reply With Quote
Old 06-14-2015, 10:03 PM   #11
35fordtn
35fordtn's Avatar
Chris,
They are $80 plus shipping (5.95 US and 14.00 International First class mail)
Old 06-14-2015, 11:51 PM   #12
countrysquire
countrysquire's Avatar
Mike,
When I get to that point of the restoration on my '41 wagon, I will be replacing the broken passenger door & vent window glasses. All of the other glass in the car, including the windshield(s), is original and much too nice to replace. The glass bugs are all quite faint and I would like for the new ones to match. Is it just a matter of experimenting to see how long to leave the etching solution on the glass?
Thanks,
Bobby
countrysquire is offline   Reply With Quote
Old 06-15-2015, 12:32 AM   #13
35fordtn
35fordtn's Avatar
Bobby,
You would normally leave the solution for one to two minutes to have a perfect etch. You could leave it on for less time to make it more faint in appearance but would take practice
Old 06-15-2015, 12:34 AM   #14
countrysquire
Gotcha, thanks. I'll be in touch to order the kit when I get to that point.
Old 06-15-2015, 07:35 AM   #15
Cecil/WV
Cecil/WV's Avatar
I'll call when I get all my new glass ready. Thanks
Old 06-15-2015, 08:11 AM   #16
glennsanders
glennsanders's Avatar
Hurry up before my chemicals are dead ,you can use mine.
glennsanders is offline   Reply With Quote
Old 06-15-2015, 08:36 PM   #17
Cecil/WV
Cecil/WV's Avatar
Thanks!
Old 06-26-2015, 08:42 AM   #18
Mitch//pa
Mike,
i just purchased your kit off of ebay
do you have step by step instructions on applying the bug.. i am doing it with the w/shield in the car on my model A
thanks
Old 06-26-2015, 07:35 PM   #19
35fordtn
35fordtn's Avatar
Mitch, yes they come with instructions. It can be done with the glass in or out of the car.
Old 06-26-2015, 08:25 PM   #20
VeryTangled
Hi Everyone, Some advice here from my experience with another vendors kit.
Mask all areas that you want to protect.
Any drop of the etching fluid that goes where it doesn't belong will leave a mark that you can't do much about.
I have two drip marks on the passenger side wing that can't be fixed without a new piece of glass.
I'm living with it, but wish I could have avoided it.
-Jeff H
