#1 |
Got a new harness to wire my taillights on a 1950 F1 Pickup. I already put the complete harness on the engine to dash. I have power on the green wire coming from light switch to the taillight at the firewall. Then I have power to the brake light switch but NO Power at the rear harness where it plugs into the taillights. What am I doing wrong???? Otherwise Power at the front of the harness but no power at the rear.
#2 |
Do you have power to the Brake SW? Tested SW with VOM?
Could you have picked up, the wrong leads on the light SW? I had to take my original headlight switch apart to clean the contacts.
Tim Downtown, Ca |
#3 |
I had a like problem and found that the bullet connectors were not pushed in far enough.
The sign of a good craftsman is how well they cover up their mistakes. |
#4 |
