#1 |
this new engine will not idle like my other model A's...they will idle to point you could almost count fan blade turning over...this new engine has high compression head, counterbalanced crank, and B grind cam...wonder if the non stock items can keep it from idling like other model A's...suggestions welcome...
The only thing worth learning is what you learn after you know it all !! ![]() |
