Old 06-10-2015, 02:50 PM   #1
Tinker
Tinker's Avatar
Default Dustless Blasting
I decided to do onsite dustless blasting for a bunch of my truck parts. I think it turned out well. Didn't have to drop parts off somewhere for a week or pick them up. It was very convenient, cost effective, and turned out very nice. Took about 4hrs including setup and take down. Nice honest guy and a hotrodder.
Pictures...
Old 06-10-2015, 02:51 PM   #2
Tinker
Tinker's Avatar
Default Re: Dustless Blasting
Now I just need to fix the bad stuff and get some sealer on it.
Old 06-10-2015, 02:56 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Did he pick up all the residue?
Old 06-10-2015, 02:58 PM   #4
Tinker
Tinker's Avatar
I didn't ask him too but he probably would have. It's raining now and being its a stone driveway most of it is gone now. It's just glass/sand and if you dig 2 ft in florida coastal area that's all your going to get anyway.
Old 06-10-2015, 03:03 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
That's what I figured, got to be done in an area where it will disappear into the ground.
Old 06-10-2015, 03:08 PM   #6
Tinker
Tinker's Avatar
If you had a large paved area you could just sweep it up. Might even be easier to clean up. Don't know.
Never used this process before so I thought I'd share. Worked well for me.
Old 06-10-2015, 04:49 PM   #7
Mike B
What did it run you, if I might ask?
Mike B is offline   Reply With Quote
Old 06-10-2015, 05:06 PM   #8
Binx
I did that in my driveway with a really light breeze using crappy quartzite sand and got dust on cars all over the neighborhood. My parts were awesome. Their cars were dusty.
Lonnie
Binx is offline   Reply With Quote
Old 06-10-2015, 05:08 PM   #9
Tinker
Tinker's Avatar
$475
I did have to spray down a little sand after the rain where all the blasting was done. Probably should have dropped a tarp down there. Still I'd say 80% of the sand/glass is gone.
Old 06-11-2015, 12:23 AM   #10
Mike B
Seems reasonable for someone to come out and do that at your place...I saw some clips of what you had done on cars...about 1000 for the car...maybe 1200??
Regardless, looks like good work.
Old 06-11-2015, 02:19 AM   #11
pooch
pooch's Avatar
Why do you say it is dustless ?
Did he use water as well ?
pooch is offline   Reply With Quote
Old 06-11-2015, 03:47 AM   #12
Tony, NY
Water, abrasive and rust inhibitor.
http://www.dustlessblasting.com/videos.html
Tony, NY is offline   Reply With Quote
Old 06-11-2015, 05:14 AM   #13
51 MERC-CT
51 MERC-CT's Avatar
Except for the rust inhibitor, the process has been around for decades
and is referred to as 'Vapor blasting'
Old 06-11-2015, 05:14 AM   #14
funrunr
funrunr's Avatar
What is the condition of the metal after blasting. Usually sandblasting leaves a very porous finish and needs to be sanded to be brought back to smooth.
Thank God
this is only a hobby!
funrunr is offline   Reply With Quote
Old 06-11-2015, 05:26 AM   #15
39portlander
39portlander's Avatar
Tinker, I wish my lower radiator pieces and floor board looked that good. Mine are like baby swiss. I'm going with Wescotts fiberglass replacements.
39portlander is offline   Reply With Quote
Old 06-11-2015, 05:33 AM   #16
34PKUP
34PKUP's Avatar
If you have a "porous" finish then sanding won't help, the panel has to be replaced.
A 'blasted' surface is one of the best surfaces to apply filler or primer to.
34PKUP is offline   Reply With Quote
Old 06-11-2015, 10:32 AM   #17
Tinker
Tinker's Avatar
The surface looks and feels just like if it was media blasted the regular way. It was washed down with Hold Tight 102 by the operator which cleans the part of media and has a rust inhibitor in it. After they dried completely I also wiped them down with ospho so there wont be any flash rust over time. In florida bare metal will flash rust immediately.
39portlander there was pieces that I thought were going to be complete junk after blasting that actual turned out great, the lower radiator pieces was one of them. And a couple that I thought were really solid, ended up revealing some holes. Win some / lose some.
Old 06-11-2015, 11:12 AM   #18
oldandtired
Tinker...Just out of curiosity, are you building a 38 or are you building a 39? The door panels are 39 and the grill is 38. I like the 38 grill a bit better than the 39 and also like the hood latch/ornament better for the 38 than the 39. The 38 grill used a little different latch assembly where it holds the hood closed than the 39.
oldandtired is offline   Reply With Quote
Old 06-11-2015, 11:22 AM   #19
Tinker
Tinker's Avatar
Good catch . Its a 38. I had the door panels from a couple donor doors so I just threw them in. They may see there way to the classifieds. I thought about doing a few other pieces not related to the truck, but figured then Id have to paint them to store.
Old 06-11-2015, 11:45 AM   #20
TagMan
The operator still needs to know what he's doing with that system. My buddy got the hood and roof of the cab on his '59 pick-up, caved in because the operator used too high a pressure. Made a real mess. The media also packed into crevasses and retained moisture. Had a heck of a time cleaning the goop out of hidden areas with a wire and compressed air.
TagMan is offline   Reply With Quote
