06-10-2015, 08:03 AM | #1 |
Barn fresh AA farm truck
I just found this truck 5 minutes from my house. I think it's a '30 AA, but could be an early '31. I need to verify the frame number as the engine is not original and is from a '29 car. Last licensed in 1957 this truck was used to haul cabbage in WNY. It is (was) green with black fenders. The odometer shows 9893 miles. The wheel base is a staggering 183 inches!! The rear frame was extended with channel iron bolted to the outside of the stock AA frame.
Plans call for a cleanup and getting this sucker running. I want to drive it around my house and maybe throw together an A speedster to haul around on it's back. Enjoy. Leaving the farm. The back 4 ft were not covered in the barn and the flatbed rotted away. Years of field mud under the hood. The engine turns freely. Cab is very solid. No holes in the floor and minimal rust in the door bottoms and cowl.
Josh Quick Quick Speed Shop "6.50 rubber really gives you the old dig when you need it!" |
06-10-2015, 08:18 AM | #2 |
Re: Barn fresh AA farm truck
Wow ! Looks amazing. A great find.
06-10-2015, 08:18 AM | #3 |
very nice i like it
kevin |
06-10-2015, 08:37 AM | #4 |
31 gas tank, one 30 front wheel, one 31 front wheel, splash aprons appear to be 31, frame is a 31 parallel frame. My first A was an AA. I love these trucks
06-10-2015, 08:48 AM | #5 |
06-10-2015, 08:50 AM | #6 |
06-10-2015, 08:54 AM | #7 |
How can you tell a '31 vs '30 gas tank? Is the fuel filler spout different or the shape of the tank itself different? I have several '30 and '31 cowls and never noticed any difference in the tanks except for my indented Murray cowl. On this truck the firewall is not indented and the roof is not all steel so I know it's not late '31. Also the cowl band seems to be painted, not stainless. Is the difference in the wheels how much hub lip there is?
Josh Quick Quick Speed Shop "6.50 rubber really gives you the old dig when you need it!" Last edited by mramc1; 06-10-2015 at 09:15 AM. |
06-10-2015, 10:56 AM | #8 |
Looks like it has BB rear spring setup. Look and see if the gas tank
ever had the steering column attached to it. If not and it has the fuel shutoff in the cab then it is a fairly rare tank, only used a couple of months. Bob |
06-10-2015, 11:39 AM | #9 |
NICE FIND !
That is in very good condition. It, probably, looks rough to your friends, but, actually, very restorable ! Thanks for posting the photos. MIKE (mikeburch) |
06-10-2015, 06:20 PM | #10 | |
Yes it does appear to have a BB rearend mated to the AA frame - if the welds are solid go thru the brakes and drive it as that setup! 99% of the people you will meet with it wont know any better :P Join usover at http://forums.aa-fords.com/index.php wealth of knowlege on there! Also check out Neil Wilsons site: http://aafords.com/ tons of research of his and tons of pictures snowing the differences and where exactly to look on your frame rail for the number.
1929 Model AA - Need long splash aprons! |
06-10-2015, 09:16 PM | #11 |
Very nice find.
FYI: I just heard of a late 1931 AA 157" with the metal top cab for sale. It is located in the Lake Elsinore, CA area, if anyone is looking for one. I have not seen it. The guy is asking $5k and it is not running. |
06-10-2015, 10:21 PM | #12 |
I've got a "AA" 1930 truck but it don't have what ever that is on the drivers side fire wall. I'm curious as to what it is.
06-11-2015, 12:05 AM | #13 | |
06-11-2015, 07:30 AM | #14 |
I looked at the truck last night before the big rains came. The tank had a mount on the bottom of it, but someone along the way cut it off. You can see there is also a ring mark on the column where the tank drop used to attach. Must have been loose or damaged so they added the later '31 style bolt on column mount.
The wheels all match and do not have the reinforced hub. The right front hub looks like it is raised in the picture because of mud on it, but is flat and is the same as the left front as well as the rears. As for the rearend I suppose that it was extended and had a BB rear installed maybe right in 1932 or 33 as it was originally used to haul coal in PA before it came to NY and became a farm truck. I can see the original AA frame is inside the channel iron frame extensions. Also the springs sit on top of the rearend, not cantileaver like all the other AA pics I have looked at. I definitely want to lift the cab to see if the AA serial is still visible.
06-11-2015, 08:40 AM | #15 |
It's a fuse block and maybe some kind of voltage regulator. I haven't gone into the electrical yet so not sure why it was added.
06-11-2015, 11:22 AM | #16 |
Drive it around the house?
Damn, you must have one big house.
06-11-2015, 11:38 AM | #17 |
06-11-2015, 01:16 PM | #18 |
06-11-2015, 04:51 PM | #19 |
Very nice looking truck. The rust should polish up very nicely. Take a look at some of the before and after pictures of my truck on my profile page. Might be something you would consider doing.
Dave / Lincoln Nebraska |
06-11-2015, 06:37 PM | #20 |
Ya can't buy patina like that in a can!!
