#1 |
I attended a local car show on Memorial Day and was looking closely at some modified Ford Coupes (what else?). One of the coupes was lowered a lot and use what appeared to be early Ford suspension components, including a dropped front axle. To eliminate the interference between the tie rod and the wishbone that the dropped axle created, the builder had swapped the spindles side-for-side and put the tie rod in front of the axle. My first thought was that it was a clever solution to the problem. My second thought was to wonder what effect that had on the steering geometry. I'd be interested to hear what others think about this solution to the problem. Thanks.
Henry |
#2 | |
![]() Quote:
![]() Last edited by V8COOPMAN; 05-29-2015 at 02:11 PM. |
#3 |
V8 is totally correct. Sometimes ether to look "cool" or to bypass other issues like oil pan clearance or a chassis that is too low, people do stupid things. Millions of dollars were spent by Ford engineering and guys do stuff like this!
#4 |
I've always been curious about this. At least related to IFS... some have steering arms in front, some behind. Are the steering arms angled differently? or is there something else designed into the suspension? I guess the question is how do they set Ackerman with the steering in front?
#5 |
What would happen if you changed the caster on the axle ??
Food for thought >>> |
#6 |
Mart. |
#7 |
klicker, any time a car is designed all these factors are taken into consideration. There are "rear steer cars" and "front steer cars" meaning the steering components are front or back of the front end components. Sometimes people modify their cars and are unaware of the consequences. There is a post somewhere on this site that shows that someone actually flipped his spindles, in other words, installed them UPSIDEDOWN, this brought the steering arms out front. This of course changed the geometry of the spindle. He then asked how to correct the greatly exaggerated camber. I am not against modifying your car but use one of the many kits available to do it safely and correctly.
#8 |
Here is a drawing that shows the relative geometry and pivot points necessary for a "front-mounted" tie rod to work effectively. For those un-familiar with this theory, you'll note a line drawn STRAIGHT through the tie rod end, king pin, and terminating at CENTER of rear axle. Same applies with tie rod BEHIND axle. DD
