#1 |
I guess considering the rest of the car it is no big surprise to find the fuel tank rusted out on my 52 Merc. Crawled underneath to find the drain plug and look into flushing and hooking up to use the tank. Well the bottom of that tank is just rust and holes. Not even good scrap iron. Guess I will be running with the auxiliary temporary plastic fuel tank for a while yet.
https://www.youtube.com/user/roosty6/videos |
#2 |
Have you checked on a new tank? I got one for my 61 comet surprisingly at a low cost.
I think it was around $165 plus shipping. Sure beat messing with the old one. |
#3 |
A good body man could fix that and you would never know it was rusted.
#4 |
Replace with tanksinc.com, steel, stainless, or poly. Good people, good product.
Nomad |
#5 |
Your tank looks like mine did. I bought a tank and sending unit from these guys for my Edsel and they were very helpful. http://www.autocityclassic.com/gas-t...ts-strap-kits/
wbedwards |
#6 |
#7 |
Why would the Merc tank be any different than the 52-53 Ford tank?
#8 |
Did you call and ask if they had an option? They don't make Edsel tanks either. My tank was for a '64 Galaxie, but with some modification, works well in my '59 Edsel.
wbedwards |
#9 |
You may want to give these guys a call-they don't list the tank but they may have a pattern to make one from. http://www.rockvalleyantiqueautoparts.com/catalog.htm
#10 |
Thanks for all the ideas and links. No doubt a tank could be modified or custom built to fit the 52. Our weak Canadian dollar right now makes shopping south of the border not so attractive.
#11 | |
![]() Quote:
I don't claim to be a expert on fixing old cars,but one thing I learned the hard way is that sometimes it is a lot cheaper in the long run to go ahead and spent the money to fix it right the first time so you can forget about it and move on to fixing other problems. BTW,I paid 240 bucks delivered for new new direct replacement Tanks,inc gas tank for my 51 Ford,and consider it to be money well spent. I even replaced the entire gas line with the new copper coated inside and out nickel 3/8th brake line so I would never have to worry about rust there,either. All it takes is the money from 1 rollback ride home plus the labor bill for repairs and you have paid for a new gas tank and never have to worry about that part of it again. |
#12 | |
![]() Quote:
As far as I am concerned this tank I have is beyond repair unless somebody could split it horizontally and weld a new bottom section on it. There is no solid metal left as I can push my fingers through most places on the bottom side. Must have had water in it when parked 30 some years ago.
#13 | |
![]() Quote:
I once had a 39 Ford that I had been running around locally to get the bugs out of,and decided to visit a friend in a nearby state with it. Filled it up with gas and took off,and got about 15-20 from home before it died. The gas tank was so full of rust it clogged up the very small siphon hose that was all I had at the time to try and clean it out. It came home on a rollback. That was the first time I had ever actually filled the tank up,and the full tank sloshing around a little washed the loose scaly rust free,and caused it to clog up the gas line. Give Tanks,Inc a call and ask them if the Merc and the Ford tanks are the same,and if not what are the differences. Even if they aren't identical I am betting a Ford tank would work with very minor modifications . If they say they don't know,get a Merc parts manual and compare the parts numbers to the Ford parts numbers. |
#14 | |
![]() Quote:
#15 |
Why didn't you say you were in Canada? There is a guy named Red Green at Possum Lodge who is handy and can make most things. If he can't make a replacement he will fix it with duck tape. Remember if the women don't find you hansom they should find you handy!
#16 | |
![]() Quote:
#17 | |
Call the tech guy at tanks.inc, tell him you problem as they don't have yours listed. I'd be willing to bet Ford / Merc. used the tank in yours in other years / models and he'll know. Worth a shot. They were very helpful with me when I was looking for a stock config. '35 Ford tank.
Nomad |
