Old 05-28-2015, 03:43 PM   #1
jon laing
Default stripped carb. threads
The horizontal front plate on my 39 deluxe carburetor is held by 3 screws. 2 of those screws are stripped. It does not leak fuel. Is there a way to fix stripped threads or should I just leave it alone. I would be more comfortable fixing the stripped threads. Hopefully I do not need a new carb. Jon L.
jon laing is offline   Reply With Quote
Old 05-28-2015, 03:57 PM   #2
Bruce Lancaster
Default Re: stripped carb. threads
You can get a helicoil kit for this...some of the threads included in basic kit are very short as needed for some of the carb screws.
From memory...Ford carbs (usually a big "Ford" on bowl, 91-99 for '39) are #10 fine, Strombergs #10 coarse, but better check me. Kits come wth what you need for quite a few threads and the necessary special tap and instructions. NOT hard to use.
Bruce Lancaster is offline   Reply With Quote
Old 05-28-2015, 05:19 PM   #3
Ralph Moore
Ralph Moore's Avatar
I just did some in my model 94's, 10-32 thread. The helicoils I got were a bit long so I ran them all the way down on the side screw goes in, then cut off excess sticking out the bottom, did this with a dremel and cut off wheel.
Ralph Moore is offline   Reply With Quote
