05-27-2015, 05:35 PM | #1 |
Help to identify an overdrive
Anybody know what kind of overdrive this is?
05-27-2015, 06:51 PM | #2 |
Re: Help to identify an overdrive
I think it looks like one I had. It was a BW but used by the orphan makes like Willis, Studebaker, etc.
05-27-2015, 07:02 PM | #3 |
Yeah, that's definitely one of the Borg Warner conversions. There used to be one or more folks that performed those conversions but they have fallen by the wayside for the more modern manufactured types and T-5s being more popular. They were basically the tail shaft & housing out of a BW 3-speed & overdrive. They generally use a cable for lockout and an electric solenoid to make them shift up.
05-27-2015, 07:56 PM | #4 |
Looks like the handiwork of Lloyd E Young, from Ohio. I just talked to him yesterday morning. He still does the Borg Warner R10 conversions.
HotRodHundred.com Reliability Runs It's about the drive!!! StreetRodder.Net The FUN is in the RUN!!! |
05-27-2015, 09:18 PM | #5 |
Thanks for the good information.
05-28-2015, 06:40 PM | #6 |
05-28-2015, 06:43 PM | #7 |
Does Lloyd Young provide the OD and torque tube, or does the customer provide the cores?
05-28-2015, 07:22 PM | #8 |
You ship your torque tube, drive shaft and coupler, and he sends it back with the OD in it and the wiring to make it work.
05-28-2015, 08:57 PM | #9 |
05-28-2015, 09:06 PM | #10 |
Klawockvet: Your photos look SIMILAR but not identical to the BW R10 set-up in my '47 sedan coupe. (i.e. where's the solenoid unit) See attached photos; markings on my BW case read "R10B-1G; W.G. Div; SB3; 2 J152". Lloyd Young thinks he did it many years ago. Last talked to him two years ago .... he was still working then at age 83. Very knowledgeable OD man.
Lloyd E Young 4915 Lithopolis Winchester Rd Canal Winchester, OH 43110 (614) 837-7832 Also, let me know if you need wiring diagram and O&P manuals. PS: Llyod says use 140 weight gear oil in these. Last edited by Drbrown; 05-28-2015 at 09:47 PM. |
05-28-2015, 09:15 PM | #11 |
Here's Lloyd's phone number: 614-837-7832
05-28-2015, 09:41 PM | #12 |
Thanks!
05-28-2015, 09:51 PM | #13 |
that sure is a good looking set up... to me it looks a lot more compact than the mitchel and a quite a bit more simple than the columbia... Mr Young is quite creative....
01-24-2016, 09:26 PM | #14 |
Anyone know what to use to attach the OD shafts to the torque tube shaft?
08-03-2020, 08:05 AM | #15 |
That shaft is cut and welded to a sprocket, the original shaft has a sprocket welded on, and there is a chain coupler that holds the two together.
I have one of these units in my '40. I know not to operate the unit in reverse in overdrive, but if the solenoid is off and one forgets to pull the lockout handle before reverse, what would happen? I'm assuming the unit would just freewheel and not damage anything but I'd like to be sure before I start driving with it. |
