Old 05-25-2015, 08:14 PM   #1
34fordy
34fordy's Avatar
Default Engine compression test
If air pressure at sea level is aprox. 14.7 lbs. per sq. in and your old
flathead had 6.3 to 1 compression ratio, does this mean that a compression test should yield about 92 to 93 lbs. if all is well in that cylinder? Or have I been breathing too many exhaust fumes?--I realize that valve timing and other factors have an effect also but just trying to see if there is a (norm) that one could use to compare--If a fellow writes in that he has 140 lb.s in each cylinder after hi-comp pistons someone else with a stock engine wonders what is wrong with his 90 lb. readings-- Don
34fordy is online now   Reply With Quote
