Old 05-24-2015, 07:24 PM   #1
Vin-tin
Vin-tin's Avatar
Default service brake shaft arm wear
On the service brake shaft, how much wear is acceptable on where the brake rod pins goes through the arm. The original pins are 5/16. A 5/16 drill bit has a bit of "slop" when pushed into the arm. The oversized pins that venders sell say they need a 11/32 hole. An 11/32 drill bit is no where close to going into the holes on the arms.
So is it best to use original 5/16 pins, or drill out the holes and use over-sized pins?
1929 Coupe
1930 Coupe
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 05-24-2015, 07:36 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: service brake shaft arm wear
I would stick with original size pins unless the hole is egg shaped enough to justify drilling it oversized.
Old 05-24-2015, 07:41 PM   #3
Vin-tin
Vin-tin's Avatar
Thanks Tom. I was leaning that way anyway, I just needed to hear it from someone with experience.
1929 Coupe
1930 Coupe
