Old 05-18-2015, 08:16 PM   #1
alt63bird
Default Frame Reinforcing? 1955 Victoria
I'm curious if any others have seen this or know why. I have a 1955 Victoria hardtop that originally was a 272/F-O-M dual exhaust car, built late January 1955 at St. Paul Assembly. Was crawling under it last night to evaluate what outer body braces need to be replaced (all 10 of them!). While looking at what it would take to lift the body off the frame in order to replace them correctly, I noticed a 2-inch wide strap of metal welded to the bottom of the frame running from the cowl to just forward of the frame kick-up at the rear wheels. I'm familiar with Ford doing this to early '56 T-bird frames due to the additional weight/lever action of the exterior spare wheel carrier, but I don't recall seeing anything in my literature collection or mentioned in the Crown Victoria Association's "FoMoCo Times" about frames for hardtops being reinforced this way. Has anyone else seen this?
Alan H. Tast AIA, LEED AP BD+C
Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI)
http://www.vintagethunderbirdclub.net
Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years"
35+ year member, Crown Victoria Ass'n.
alt63bird is offline   Reply With Quote
Old 05-18-2015, 11:59 PM   #2
CrownVic55
CrownVic55's Avatar
Default Re: Frame Reinforcing? 1955 Victoria
That big steel strap is welded to the bottom of the frame on my 55 Crown Vic. Ford put that on hardtops and convertibles, I believe.
CrownVic55 is offline   Reply With Quote
Old 05-19-2015, 06:13 AM   #3
darrell
it was used in 55 and a few 56s.as you said hardtops and crowns to stifin the frame.in 56 they made the framr 1/32 thicker and done away with it.
darrell is offline   Reply With Quote
Old 05-20-2015, 08:33 AM   #4
Ole Don
Ole Don's Avatar
My 54 Vicky had the strap welded on the bottom as you describe.
Ole Don is offline   Reply With Quote
Old 05-26-2015, 03:15 AM   #5
Big Red 51
Big Red 51's Avatar
Ford did that on '52 & '53 Vickys also.
Big Red 51 is offline   Reply With Quote
Old 05-26-2015, 03:33 PM   #6
mikhett
Its not on my 56 Vicky.
mikhett is offline   Reply With Quote
Old 05-26-2015, 07:01 PM   #7
Jay in Mass
I had six 56 Fords over the years. One of the Victorias had those straps on it.
Jay in Mass is offline   Reply With Quote
Old 05-26-2015, 07:40 PM   #8
darrell
a friend had one with the straps on it i dont know if they were leftovers or someplace was still putting them out.
Old 05-31-2015, 07:29 PM   #9
junkyardjeff
I will have to look at my 55 sunliner and see if it has it.
junkyardjeff is offline   Reply With Quote
Old 05-31-2015, 07:39 PM   #10
rowens55
rowens55's Avatar
ok,, so NOW I have ta go look at MY crown vic!! Doggone it, im such a lemming.......
Alive n kickin n mostly kickin!
rowens55 is offline   Reply With Quote
