Old 05-17-2015, 11:19 AM   #1
SofaKing
SofaKing's Avatar
Default 21 stud rear main seal
I need a photo or description of how the rear main is assembled. It seems like I am missing a part or have the wrong seals. None of my books gives a suitable description. The parts on the left are the 21 stud parts, the others are from 59a. You can see that the rope seal is too small for the groove in the bearing cap. Is there another piece that fills that gap? Also, the crank has two flanges that look like they will straddle the seal when it is installed. Is that how this is supposed to work? It almost looks like it might be a labyrinth type arrangement. If you have a photo of any missing parts that would be most helpful. Thanks!
SofaKing is offline   Reply With Quote
Old 05-17-2015, 11:25 AM   #2
bobH
Default Re: 21 stud rear main seal
I assume you are aware that the 21 stud did NOT originally have a seal??
Curious... what is it that you are trying to do? Convert to 59A stuff?
bobH is offline   Reply With Quote
Old 05-17-2015, 12:27 PM   #3
SofaKing
SofaKing's Avatar
Actually, no I was not aware. It looked to me that it worked like jseery described, that's what I meant by labyrinth seal. Both slinger rings remain on the crankshaft. Thanks!
Are there improvements, seems like this must blow oil into the clutch area?
Old 05-17-2015, 01:21 PM   #4
JSeery
JSeery's Avatar
The idea is very little oil gets past the slinger. There is a hole in the bottom of the cap to allow the oil to drain back into the oil pan. Obviously Ford decided that the rope seal was a better approach in latter models, but the slinger worked well enough.
Old 05-17-2015, 11:34 AM   #5
JSeery
JSeery's Avatar
Yep, does not use a seal, uses a slinger. Do you have the correct crankshaft? The crankshaft should have the slinger on it, it is part of the original machine work of the crank. Sometimes they get machined off for whatever reason.
Old 05-17-2015, 01:13 PM   #6
Jack E/NJ
Jack E/NJ's Avatar
What? You don't like an oil-soaked clutch? How about an oil-soaked floor instead? That's what that little hole's for at the bottom of the bell-housing --- the one with the loose cotter pin rattling around in. 8^) Improvements aren't worth the trouble.
Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 05-17-2015, 07:32 PM   #7
Talkwrench
Talkwrench's Avatar
Does the 37 21 stud not have a cork type seal there?
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 05-17-2015, 08:10 PM   #8
flatheadfan
flatheadfan's Avatar
This is the typical pre-rope rear seal that I am familiar with. The seal is an upper and lower aluminum casting that fits in the block and the rear main. The crank slinger fits in it.
Tom
flatheadfan is offline   Reply With Quote
Old 05-17-2015, 08:16 PM   #9
JSeery
JSeery's Avatar
Yep, that's what they look like. Should be somewhat V shaped inside. The later engines use a similar style of insert but with a rectangluar grove that is not near as deep that holds the rope seal. In the last photo you can see the drain back hole.
Old 05-18-2015, 08:36 AM   #10
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Ford never use a rope seal until 46 with the 59AB engine, don't try to put that seal in that groove where the slinger on the crank goes. A good crank and bearings leak very little, don't over fill the crank case. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 05-18-2015, 08:56 AM   #11
Jack E/NJ
Jack E/NJ's Avatar
JSeery>>>In the last photo you can see the drain back hole. >>>
Yep, in the old days that's the drain & pipe that got plugged up with sludge. 8^)
Jack E/NJ
Old 05-18-2015, 12:33 PM   #12
SofaKing
SofaKing's Avatar
Jack E/NJ
I am missing the lower half of the aluminum casting. Where can I get one and has anyone ever heard of leaving it out so it is not clogged by sludge? Wondering why it is missing? Thanks to everyone and especially for the photos, now I know what it looks like....
Old 05-18-2015, 01:30 PM   #13
Jack E/NJ
Jack E/NJ's Avatar
According to Reds Headers "In the 1932 to mid-1936 engines, there is seldom a pot metal labyrinth seal piece in the rear main bearing cap. There is just a cavity that leads to the drain hole, and probably a tube. These earlier engines do have a pot metal labyrinth seal piece in the block."
http://www.reds-headers.com/html/red...e_talk_24.html
Jack E/NJ
Old 05-18-2015, 07:12 PM   #14
SofaKing
SofaKing's Avatar
it gets curiouser and curiouser. I suppose I'll assemble it without the bearing cap half of the aluminum casting and see what happens. These old cars are more quirky than I imagined, thanks again for the help.
Talkwrench- there is a cork seal on this engine that seals the bearing cap to the oil pan, it fits in a groove in the cap and the oil pan wall butts up against it. The oil pan has no flange at the contact point, just the wall thickness.
Old 05-18-2015, 07:38 PM   #15
Jack E/NJ
Jack E/NJ's Avatar
That cork/rubber seal can be a troublemaker. On installing, tends to not stay in place. Sometimes get twisted or otherwise poorly contacting all the surfaces and can leak like a sieve. I use a neoprene seal affixed with some contact cement or rtv so it doesn't move when installing the pan.
Jack E/NJ
Old 05-18-2015, 07:54 PM   #16
Kurt in NJ
Kurt in NJ's Avatar
The later replacement blocks had the cap made to take either type of seal so the original crankshaft or a new crankshaft could be used
Old 08-02-2015, 07:41 AM   #17
ford1933-2008
Gentlemen,
Hopefully someone can assist me. The slinger pictured above thumbnail 2 is the slinger I have in my 36 "L" block. It is broken. Can someone advise where I can obtain a replacement or is there a replacement solution?
Hopefully you can assist me
David
[email protected]
ford1933-2008 is offline   Reply With Quote
Old 08-02-2015, 07:58 AM   #18
JSeery
JSeery's Avatar
Originally Posted by ford1933-2008 View Post
Gentlemen,
David
[email protected]
The base part numbers are 6335 and 6336. the 35 is the upper half and the 36 is the lower half. You can purchase them through several sources, VanPelt is one. The VanPelt listings start with 1936.
Note: MACs list them as part # 32-17646-1
Old 08-02-2015, 05:14 PM   #19
ford1933-2008
Fantastic news, thank you
