Old 05-07-2015, 09:03 PM   #1
THR1LL3R
THR1LL3R's Avatar
Default Replacing window felt f1 pickup
Bought the felt and clips from Dennis carpenter not entirely sure how to clamp the clips to the felt and even get them in the right spot inside the door. I do relize the window should be out. Is there a special crimping tool for the job? Any tips or tricks would be appreciated.
Thanks Dave
THR1LL3R is offline   Reply With Quote
Old 05-07-2015, 10:37 PM   #2
gearhead1952
gearhead1952's Avatar
Default Re: Replacing window felt f1 pickup
I remember that there were clips that clamped onto the felt then fit into holes in the door. But only for the bottom of the window opening. I used a pair of pliers nothing fancy. The real problem tho is when you try to push the clips into the holes. The repro clips are crap and won't stay in the holes. I save them now out of old doors. There are small screws that hold the felt channels for the top and rear of the window opening.
gearhead1952 is offline   Reply With Quote
Old 05-08-2015, 06:25 AM   #3
GreenMonster48
GreenMonster48's Avatar
Yeah, what gearhead says. The clips are absolute garbage and don't stay in the doors. I launched mine across the yard in a tirade of expletives and was too incensed to try to fix the situation.
GreenMonster48 is offline   Reply With Quote
Old 05-08-2015, 07:23 AM   #4
chap52
chap52's Avatar
Yep...those clips? I believe there are still a couple of them rattling inside my doors.
I got the clips aligned with he holes and took a slot screwdriver the width of the channel and placed the blade of a screwdriver in the channel, using a twisting motion pressed the clips into the holes. That worked pretty well.
chap52 is offline   Reply With Quote
Old 05-08-2015, 07:47 AM   #5
Barry-ct
Barry-ct's Avatar
Those felt kits with those clips are pure garbage! I used more expletive deletives on those things while trying to get them in the right places and to stay in the holes in the door. Nothing is the same as the originals, either in quality and being the same shape! I hope I never do another one ever again. Vintique is the one who makes these kits for everyone else. That should explain why they're crap.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 05-08-2015, 11:21 AM   #6
waterboychuck
waterboychuck's Avatar
The material is good but the clips are not. After several tries I too tossed mine and used 3M glue.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 05-08-2015, 02:21 PM   #7
Ross F-1
Ross F-1's Avatar
I went around and around with Dennis C's guy over my felts. They came to me (3 sets in a row) with the felt ruined on the curved bit near the back. They bend them after attaching the felt, and guess what, it rips. For clips I gave up on theirs (garbage) and bought Vintiques clips off eBay. They are darn near as good as OEM. Why they can't attach good clips in the correct locations at the factory is beyond me...
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 05-08-2015, 02:42 PM   #8
glennsanders
glennsanders's Avatar
Call me I tell the best way I found 301 514-5017
glennsanders is offline   Reply With Quote
Old 06-19-2015, 06:54 PM   #9
THR1LL3R
THR1LL3R's Avatar
What 3m glue? They make quite a few.
Old 06-19-2015, 08:53 PM   #10
Barry-ct
Barry-ct's Avatar
Glenn, tell us here what you did. We all would sure like to know.
Barry
50 F-1
Old 06-20-2015, 10:41 AM   #11
waterboychuck
I used this 3M product.
http://www.tcpglobal.com/MMM-8008.ht...7#.VYWJbflViko
Old 06-20-2015, 11:44 AM   #12
glennsanders
I use 3 m marine apoxie,I use tongue depressors are paint stick's .I do 1 strip on a door a day.1st measure an cut to the right size .2nd small bead of 3 m on strip put in place wedge in depressors to hold in place ,wipe off excess glu, do other door.3rd do other side of door next day.
Old 06-20-2015, 12:34 PM   #13
Barry-ct
Barry-ct's Avatar
My clips are holding, all except one I had to use wedges to get the clips to stay. I will get some of the 3M Marine epoxy and re-do them.
Barry
50 F-1
Old 06-20-2015, 12:45 PM   #14
Doug-F1
Doug-F1's Avatar
This is good info. I had been thinking it was something I was doing wrong. Sounds like the 3M stuff is the way to go.
Doug-F1 is offline   Reply With Quote
Old 06-20-2015, 11:19 PM   #15
THR1LL3R
THR1LL3R's Avatar
There's no way weather stripping adhesive is gonna work
Old 06-21-2015, 09:36 AM   #16
glennsanders
That's the way we have did it for a couple years now and has worked fine.
Old 06-21-2015, 05:52 PM   #17
THR1LL3R
THR1LL3R's Avatar
Just used Vintiques clips and it's a night and day difference. They are a little tricky but they are much better than the ones that come with the anti rattle strips.
Thanks again everyone.
Old 06-21-2015, 08:10 PM   #18
Barry-ct
Barry-ct's Avatar
My felt kit came in a Vintiques box, even though I got it from LMC. I really hated the clips. This was 2 years ago. Maybe they have been improved.
Barry
50 F-1
Old 06-21-2015, 08:20 PM   #19
Ross F-1
Ross F-1's Avatar
I get the impression that the Vintiques clips that come in the kit are different than the clips they sell alone.
