Old 05-07-2015, 06:16 AM   #1
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default extended throttle
Does anyone know where I can get a std. size throttle shaft for a 94 Ford carb? it's .277 dia. This broken one sticks out about 1-1/2in. on each end. All I can find is the .005 oversize one. Thanks Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 05-07-2015, 08:21 AM   #2
scicala
scicala's Avatar
Default Re: extended throttle
Charlie NY makes extended shafts (.282" dia). Maybe he can make one to you're specs ?
You can also ream you're throttle body shaft holes to 9/32" if using a .282" shaft.
Sal
