Old 05-03-2015, 01:35 PM   #1
clay co 27
Default manifold stud washers
Which way does the concave manifold washer go? Thanks, Carl
clay co 27 is offline   Reply With Quote
Old 05-03-2015, 01:38 PM   #2
kenparker
kenparker's Avatar
Default Re: manifold stud washers
Crown goes to the outside - toward the nut
kenparker is offline   Reply With Quote
Old 05-03-2015, 03:19 PM   #3
fiddlybits
fiddlybits's Avatar
EXACTLY
Bad example in this thread
https://www.fordbarn.com/forum/showthread.php?t=162712
fiddlybits is offline   Reply With Quote
Old 05-03-2015, 09:21 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Concave side always faces in, so the nut puts pressure to the high center of the washer.
Old 05-03-2015, 11:09 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Take a moment and think about it.
If the thickness on the two manifolds are different the washer tilts. With the high side towards the nut it "compensate" for this tilt.
In the picture below all the elements are the same size, the curved "washer", the black boxes are the manifolds, and of course the nuts.
