#1 |
Seen an add on tv for seafoam, Anyone use it in there flathead motors ? Pros, Cons ?
Thanks |
#2 |
No opinion on if it works but be sure to use it outside. Not in enclosed spaces. Huge clouds out the exhaust from what I recall seeing someone else use it.
#3 |
I have been using it for the gasoline in my '37. No problems with it at all, and it seems to help keep the gas from going bad.
Dwayne |
#4 |
I use it all the time with no issues. I drive my '36 all the time and run Seafoam every so often to keep the 97 from gumming up.
H36
Thank you, H36 |
#5 |
I have used it successfully in two of my old tractors to help mitigate carburetor problems caused by ethanol gas and long periods of inactivity. I do not now use ethanol gas in any of my engines except for the car and pickup.
#6 |
#7 |
Its good stuff!
#8 |
I'm sure it can't hurt. And use this website to find Ethanol free gas in your area:
http://pure-gas.org |
#9 |
We used to call it "Mechanic in a Can". Seriously, I fill my tanks and add a can of SeaFoam every fall when I put my cars away. I've never had a problem come spring (we do have easily attainable non-ethanol gas here). I usually add another can in the early summer. It's getting expensive lately. The last I bought was at Fleet Farm for about $9 a can on special; used to be a couple of bucks, IIRC.
#10 |
I use in every gasoline engine I own that has sat or will sit for any length of time. It works for me......MARK
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
#11 |
I swear by it. I always use it when going on a tour. After about 40 miles
cars smooths out and operates with very light throttle . Just like driving with a tail wind. |
#12 |
Used it both in oil and gas on a motor that hasn't been started in years! I also poured it directly into the carb while running the motor. Worked great but did make a lot of smoke.
"DON'T CRUSH IT....RESTORE IT" |
