Old 04-27-2015, 05:18 PM   #1
donQ
Default Generator rotation
I was checking a number of model A generators. First I checked to see if they would run as a motor. All but one ran clockwise when facing the pulley. This one ran CCW. I then used my motor fixture to see if they would generate. Most charged at 3-4 amps and the voltage at the battery increased. The one that motored CCW, showed - 9 amp on the ammeter and dropped the voltage at the battery.
Is this simply a case of the residual magnetism being of the wrong polarity, have the field winding connections been interchanged, or is there some other problem?
Thanks
DonQ
donQ is offline   Reply With Quote
