10-03-2010, 06:52 PM | #1 |
28-31 Model A zenith carb top with float
City:
Southington
State:
Ct
Need upper portion of 28-31 Ford Model A cast iron Zenith carb, preferebly with the float.
10-04-2010, 02:21 PM | #2 |
Re: 28-31 Model A zenith carb top with float
#1 Has had a mounting bolt hole flange broken off and brazed back in place. #2 Has rust pits on lower rim where it meets the rim of the lower section, of course with gasket between. Rim needs to be filed smooth and gas line hole needs threads chased. [email protected] |
