Old 04-22-2015, 01:33 PM   #1
rob63mess
rob63mess's Avatar
Default brake switch
I put an aftermarket brake switch on the 30 roadster. The problem is that the shaft has to be almost completely depressed into the switch housing before the circuit will open. The brake rod plunger can be all the way against the crossmember and the circuit wont open. Is it possible that the switch is bad?
rob63mess is offline   Reply With Quote
