04-20-2015, 12:07 PM | #1 |
6 lug bolt pattern
Can anyone point me to drawings or illustrations showing Ford 6 lug bolt patterns? I'm trying to identify hubs used on my V8 60 powered rail frame midget. It uses mainly Ford parts for the front suspension. It has a narrowed Model A front axle, '32-24 Ford spindles and Ford 6 lug hubs.
I'd like to purchase a couple new hubs but can't seem to find their origin. I've talked to some Ford tractor guys and they say they are not 9N or 8N. Any help or leads would be great. Thanks! Bart |
04-20-2015, 12:33 PM | #2 |
Re: 6 lug bolt pattern
Probably 8N Ford tractor.
Bob |
04-20-2015, 12:33 PM | #3 |
My first thought was that they look like my '54 NAA Ford hubs, but I think they are the same as 8N.
04-20-2015, 12:35 PM | #4 |
My guess is thats a Model T back half hub for a wood wheel. Someone drilled the hub and welded in the studs.
A wood model T hub had six bolts.. Thats how you could have done it back then , beats me on the wheel used though.. |
04-20-2015, 12:35 PM | #5 |
Model T? Some T's used twelve spoke wooden wheels with six lugs, but I have no idea about adapting T hubs to early V-8 spindles. Machine work on hub or spindle, bearing swap? With the T spindle being simpler I would like to see the spindles on your midget, I'm betting they were machined for T hubs.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
04-20-2015, 12:46 PM | #6 |
04-20-2015, 12:52 PM | #7 |
It looks like a 6 on 5 sprint car/midget hub. Pretty much standard on vintage circle track cars till spline drives came in.. Still available from a lot of small race car equipment suppliers.
04-20-2015, 12:56 PM | #8 |
I guess it doesn't look like 8N or T unless the outer end of the T was cut off.
Bob |
04-20-2015, 12:58 PM | #9 |
04-20-2015, 01:41 PM | #10 |
I will see if any of my ancient friends have any info.
04-20-2015, 01:48 PM | #11 |
Didn't the 3/4 ton F2 pickups have 6 lugs?
04-20-2015, 02:38 PM | #12 |
04-20-2015, 02:57 PM | #13 |
Pretty sure it is a T hub with the end cut short and a bearing fitted somehow. Or appears that way in the pictures.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
04-20-2015, 03:55 PM | #14 | |
Also inside the smaller (outer) bearing casting a S inside a circle just past where the race stops. I have plenty of wheels. There are lots of steel and magnesium 12" midget wheels available that fit the bolt pattern. This is a finished car I'm doing some updates to. |
04-20-2015, 03:56 PM | #15 |
04-20-2015, 04:22 PM | #16 |
Six lug wheels were/are used on a lot of ag equipment.
04-20-2015, 04:35 PM | #17 |
Don't forget the fact that there is a "FORD" script on THIS hub. DD
04-28-2015, 01:34 PM | #18 |
04-28-2015, 02:46 PM | #19 |
1950 Ford f2 trucks Where eight Lug Wheels Good Luck
04-28-2015, 06:50 PM | #20 |
Early midgets used a lot of model T parts like frames, axles, cross members, so more than likely they are T.
