Old 04-19-2015, 07:09 PM   #1
Bill Goddard
Bill Goddard's Avatar
Default Disappearing grease in universal
When I put the universal in originaly, I packed the casing with grease. Now 1300 miles later I pumped 6 more shots in with my grease gun. If I do this every so often where does the old grease go? I don't see it squeese out like other joints. Bill G
Bill Goddard is offline   Reply With Quote
Old 04-19-2015, 07:22 PM   #2
harleytoprock
Default Re: Disappearing grease in universal
When you pump the grease have a speedometer drive bolt removed. If the unit gets pressurized the grease is forced into the tranny or passes by a weak driveshaft seal.
harleytoprock is offline   Reply With Quote
Old 04-19-2015, 11:31 PM   #3
Smog Tech
Smog Tech's Avatar
I take off the speedometer drive. When I see grease, I stop pumping. If you pump too much it can go up the speedometer cable into the speedometer!!
Smog Tech is offline   Reply With Quote
Old 04-20-2015, 06:33 AM   #4
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
It's going up your speedo cable. Pump enough and you will see it in your speedo window. You don't want that.
Jacksonlll is offline   Reply With Quote
Old 04-20-2015, 02:52 PM   #5
Patrick L.
Patrick L.'s Avatar
This apparently is fairly common. With an original style non sealed bearing, transmission oil will pass thru and mix with the u-joint grease.
Many a transmission has been filled with grease unknowingly. It could also end up in the torque tube, speedo housing or thrown out past the felts.
I now remove the speedo drive anytime I pump grease into the clam shell.
Old 04-20-2015, 03:47 PM   #6
P.S.
My Tudor has the old u-joint grease come out the felts where the clamshell clamps around the front of the torque tube. It usually comes out slowly as the joint moves while driving, so you don't notice. In fact, if I wasn't so OCD about my stuff, and the tudor being a nearly fine point car, I would probably never notice it.
Like the guys mentioned above, if your Model A has some wear on it, when pumping grease in, the excess could work its way into the torque tube, speedometer cable, etc. If grease makes its way into the speedometer itself, you have way overdone it.
Each time I lube the chassis, I just put 2 pumps into the u-joint housing. Since it is already full and also gets some of the tranny fluid through the shafts, adding just 2 pumps of grease each time is plenty.
P.S. is offline   Reply With Quote
Old 04-20-2015, 04:41 PM   #7
harleytoprock
And if your using a chassis or high temp grease , none of it is getting into the u-joint bearings.
Old 04-20-2015, 05:35 PM   #8
Patrick L.
Patrick L.'s Avatar
If the transmission has an original style bearing then a bit of the the oil is mixing with the grease as previously stated.
Old 04-21-2015, 11:25 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
Patrick,
You make a good point. If the transmission is sealed, the u-joint doesn't get any transmission oil. I think I need to pump a small amount of gear oil into the u-joint annually to augment the grease because I did seal the transmission in my 190A.
Bob Bidonde
Old 04-21-2015, 01:33 PM   #10
Patrick L.
Patrick L.'s Avatar
Originally Posted by Bob Bidonde View Post
Patrick,
You're right. I mix grease with oil to make a 'goop' [ technical term] and keep it in dedicated gun. Kinda like when I was a kid we had a gun full of 140 weight for that little grease fitting on the steering boxes.
Old 05-24-2025, 10:28 AM   #11
Skyking227
Wow, was wondering how to know too much grease.
Thanks so much
Skyking227 is offline   Reply With Quote
Old 05-26-2025, 08:23 AM   #12
KenBolton
It would be a good idea to pull the tranny cover. You may be shocked at how much grease
is in it. Then, then next question is; “Where did all the tranny fluid go?”
KenBolton is offline   Reply With Quote
Old 05-26-2025, 11:01 AM   #13
AzBob
Same thing happened to me when I last checked fluid levels. Found tranny full of grease and no sign of the displaced gear oil.
I am another one who upon advice of those on the forums packed the u joint full of grease upon assembly and later with the speedo gear off and pumped until visible. From now on, I’ll just give the u joint a pump or two once a year.
AzBob is offline   Reply With Quote
Old 05-30-2025, 05:53 PM   #14
rotorwrench
rotorwrench's Avatar
Ford used gear oil conservatively mixed with soda soap for a semi-fluidic form of lubricant. In the modern era, many folks use John Deer Corn header grease that is a modern thixotropic lubricant which is also a semi-fluidic grease. It goes in and stays in better. It's also better at permeating the bushings in the U-joint while in motion. The stuff solidifies a bit after motion stops.
Regular grease stays solid and just gets pushed out of the way by centrifugal forces. The bushings don't get lubed very well with that stuff.
