04-17-2015, 04:09 PM | #1 |
35 Radiator Pan mounting
Mounting my radiator and pan on the 35 pickup with a 59A engine. The pan that goes under the motor and bolts to the frame will not clear the fan pulley on this engine to bolt in place. Not sure if it's the pan or the outside pulley that's the problem. There is no reason for this extra outside pulley except the crank connection is on it.
FYI The blue jack in the picture is under the front axle not the pan. It's one of them "tropical contusion" pictures !!.. Would appreciate your thoughts on making this pan fit .. Thanks
Lineman, the only dumb animal that can harness himself !! |
04-17-2015, 04:57 PM | #2 |
Re: 35 Radiator Pan mounting
