Old 04-16-2015, 06:08 PM   #1
Fullraceflathead
Fullraceflathead's Avatar
Default How to tell the actual Year of Commercial Model A's
I thought I read somewhere (Can't find it now) that the Commercial Model A's didn't change years with the beginning of Jan. I thought they changed years in May or sometime later than the beginning of each new year.
Is there any way to verify this?
I have a 1928 or so I believe, Roadster pickup. The engine dates it to November 1928, IF it's the Original engine. No the frame numbers never been seen. I'm putting this back into the California DMV System soon (Good luck!, I know).
I was told it was a 1928 by the last owner, he had it since the '60's.
It was originally an abandoned Model A found out in the Desert in the early '60's. The history before this is long gone. It was registered in California up untill the '80's. It was parked until I bought it last year.
Could this still be a 1928 or most likely a 1929? The Pink slip from the '60's is lost and it was listed as a 1929. With the high volume of Model A production in late '28 and early '29 I can't see how this engine sat around for too many weeks before being used. This also assumes it's the original engine.
I'd like to hear some thoughts on this if someone can help.
Thanks,
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 04-16-2015, 06:43 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: How to tell the actual Year of Commercial Model A's
I would think if you have last owner's name they could verify year OR run the engine # by them to see what comes up.
Paul in CT
Old 04-16-2015, 07:10 PM   #3
Marco Tahtaras
Marco Tahtaras's Avatar
It's on the border and could go either was. Is there a visible date on the gas tank? That could push it later possibly. There is virtually no difference between an Open Cab pickup built in November 1928 and one built 3-4 months later.
It's worth noting that in those days California used the "Date First Sold" for the year on the title.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 04-16-2015, 07:15 PM   #4
Bob C
You are probably thinking of the 1930 model year. The P/U and AA used
the 28-29 sheet metal until mid year.
Bob
Old 04-16-2015, 08:21 PM   #5
Fullraceflathead
I stripped the paint on front left side of the cowl/gas tank to see the Date Stamp. Mine has none.
-Henry Ford
1941 Willy's Pickup
Old 04-17-2015, 02:35 PM   #6
Chris Haynes
Chris Haynes's Avatar
Possibly an Early '30. Of course the frame number will nail it. Another thing to look at is the floorboards. The Early '30 has a different bolt pattern than the '29. Late Early '30's used a twist lock gas cap instead of screw on. What are the date codes on tranny and rear end, if they are the originals.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 04-17-2015, 03:37 PM   #7
Fullraceflathead
Engine is dated Nov. 1928, Trans is a AA 4 Speed the was retrofitted, casting date on it is 2-13-31.
I think it is an early '29 if not late '28.
-Henry Ford
1941 Willy's Pickup
Old 04-18-2015, 02:25 AM   #8
Chris Haynes
Have you checked the floor board bolt pattern? '28 and most '29 have date code on firewall. Late '29 and Early '30 do not.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 04-18-2015, 05:02 AM   #9
RonC
RonC's Avatar
Make a table listing part changes on the left and date changes across the top from the judging standards and service bulletins and service letters for as many parts of your truck as you can. You should be able to date it within 3 months if your truck is mostly original.
RonC is offline   Reply With Quote
Old 04-18-2015, 11:20 AM   #10
Charlie Stephens
Another confusing thing is that when a change was made for passenger cars the extra parts were used on commercial vehicles until they were exhausted. The serial number on the frame is probably the best source to determine a year. Keep looking for the VIN (serial number). The DMV will probably want to see it (or have it verified). Sometimes it takes polishing and acid etching to get the VIN visible.
Charlie Stephens
