Old 04-13-2015, 07:20 AM   #1
A TRUCK
A TRUCK's Avatar
Default Gasket for a Snyders 6:1 HC Head
Hi
Any recommendations (part no.) on the best gasket to use for one of these Snyders 6:1 HC Heads?
Thanks
A TRUCK is offline   Reply With Quote
Old 04-13-2015, 08:25 AM   #2
kenparker
kenparker's Avatar
Default Re: Gasket for a Snyders 6:1 HC Head
call and ask Don Snyder.
kenparker is offline   Reply With Quote
Old 04-13-2015, 09:45 AM   #3
a-bone newby
a-bone newby's Avatar
I am not a expert but some say that a copper gasket that matches the head is best I wonder what kind of reply was the above the question was can any body help I thought this forum was to help barners out
a-bone newby is offline   Reply With Quote
Old 04-13-2015, 10:08 AM   #4
Ron/IA
a-bone - Ken's answer was simply to suggest talking to the vendor (in this case Snyder's) since they produce the high compression head, and should be able to recommend the proper head gasket. Many people just don't think of that, or they are looking for more than one suggestion.
Ron/IA
1929 Fordor Steelback
Hawk A Model A Ford Club
http://hawkamodelaclub.org/
Ron/IA is offline   Reply With Quote
Old 04-13-2015, 12:15 PM   #5
a-bone newby
not dissing ken I thought there would b more replies sorry ken
Old 04-13-2015, 06:37 PM   #6
A TRUCK
A TRUCK's Avatar
Thanks (a-bone newby) - Yes, you are correct. I was merely asking if anybody had a recommendation or part no. for a gasket with this HC head and Yes, (kenparker) I know I can call Don Snyders and I'm sure he would be suggesting one of his OWN gaskets, which isn't a problem - I just wanted OTHER peoples opinions.
Old 04-13-2015, 07:13 PM   #7
MikeK
MikeK's Avatar
Originally Posted by A TRUCK View Post
. . . I know I can call Don Snyders and I'm sure he would be suggesting one of his OWN gaskets, which isn't a problem - I just wanted OTHER peoples opinions.
This one: LINK Fits the 6.0 head correctly, kevlar reinforced graphite facing material mechanically bonded to both sides of a perforated steel core, steel fire rings. Use copper spray, retorque twice in first 100 miles. Doesn't seep coolant through the core like copper sandwich gaskets, much stronger at the siamese points.
MikeK is offline   Reply With Quote
Old 04-13-2015, 07:16 PM   #8
A TRUCK
A TRUCK's Avatar
Thanks MikeK - much appreciated.
Old 04-13-2015, 07:54 PM   #9
glenn in camino
glenn in camino's Avatar
I always use copper clad head gaskets and lots of Coppercoat spray.
glenn in camino is offline   Reply With Quote
