#1 |
Hi all,
I've done some simple searches, and will continue to search the archives, but in the mean-time if someone has comments or can point me to a particular thread or post, I appreciate it. At some point I need to clean and coat the inside of my gas tank, but it's going to be a while. I'm searching the forums to find the best method, and saving up money, but in the mean time I want to try to keep it from getting any worse. Obviously I want to drain it. Then to limit ongoing rust I was thinking of 'hermetically' sealing the tank with a sacrificial metal inside. Kind of like zincs on a boat*. From what I understand those pocket hand warmers contain iron filings. When you expose them to oxygen they generate heat. And in the process consume oxygen. Some survivalists / prepper types put hand warmers in with their sealed up food to absorb the oxygen and help preserve the food. Why wouldn't that work in a gas tank to impede the rusting process? Obviously I would need to plan for a way to remove the sacrificial metal easily later. And if you've read this far... I have a bunch of 0000 steel wool. Instead of buying handwarmers I may put some damp steel wool in a vented container that will fit in the tank. *I do realize the marine example is galvanic corrosion, so not a perfect analogy.
'29 standard coupe project build thread |
