Old 04-06-2015, 02:03 PM   #1
waynes
Default Machinist Recommendation Needed
I have a set of mis-matched Weiand "S" heads that I need the chambers machined so they have same volume and compression ratio. Can anyone recommend a shop with a good reputation I could send them to? I'm located in Jersey but willing to ship them out.
waynes is offline   Reply With Quote
Old 04-06-2015, 07:13 PM   #2
Tim Ayers
Default Re: Machinist Recommendation Needed
P&W Machine
28 Fanok Rod
Whippany, NJ
973-887-1377
Old 04-07-2015, 05:42 AM   #3
Terry,OH
Terry,OH's Avatar
Or: Motor City Flatheads 313-529-3363 in Detroit. See if you can find their web page.
Old 04-07-2015, 06:34 AM   #4
Tim Ayers
Terry:
Is he still in business? I thought he closed shop long ago?
Tim
Old 04-07-2015, 08:52 AM   #5
sidevalve8ba
sidevalve8ba's Avatar
Originally Posted by Tim Ayers View Post
Terry:
Tim
I thought his shop had closed, too. Health problems of some sort I heard.
sidevalve8ba is offline   Reply With Quote
Old 04-07-2015, 09:55 AM   #6
GOSFAST
GOSFAST's Avatar
In order to make that somewhat cost-effective you would need to locate someone with a "specific" CNC program dedicated to those particular heads. This would keep the labor (time) relatively low!
The only other way is going to be time-consuming, not difficult at all, but time-consuming! A Bridgeport might be a great advantage.
Thanks, Gary in N.Y.
P.S. If you are somewhat "mechanically-inclined" and could CC the chambers on your own you would be able to handle the job! In the end (time-wise), it's going to depend on the total amounts of material removal!
GOSFAST is offline   Reply With Quote
Old 04-07-2015, 01:14 PM   #7
flatjack9
flatjack9's Avatar
What do you mean by volume and compression ratio? As the volume increases, the compression ratio goes down.
Old 04-07-2015, 02:25 PM   #8
HP Hunter
Looks like hes just saying the heads arent even?
Harry
HP Hunter is offline   Reply With Quote
Old 04-09-2015, 08:43 AM   #9
waynes
One head looks to have been worked in area between valve and piston chambers. Got it in an estate sale of a former NJ stock car driver. Not sure why it was done or if Weiand produced different versions of the "S" heads it sold. There is no valve relief work done on either head. I could probably do the work but not sure how much material I can safely remove.
Harry
