Old 04-05-2015, 07:04 PM   #1
jrhaelig
jrhaelig's Avatar
Default Restored My Cracked Steering Wheel
Like many of us I had cracks at the top and bottom of each spoke on my steering wheel.
It was to the point that one of the cracks bloodied my finger a few months ago, so I knew I needed to do something.
Yesterday I mixed up some JB Weld & stuffed the cracks. A few minutes with some 80 grit followed by 150 gave me some excellent results.
A few strokes with a black marker and by golly it's as good as the rest of the truck - and no more bloody fingers!
Flash is a bit bright, but the daylight results are great.
John Haelig
Bridgewater, NJ
1939 Ford Pickup
1963 Lincoln Continental
1939 Buick
jrhaelig is offline   Reply With Quote
Old 04-05-2015, 08:01 PM   #2
RalphG
RalphG's Avatar
Default Re: Restored My Cracked Steering Wheel
That JBweld is great stuff. My steering wheels don't need it but if they did I wouldn't hesitate to try it.
RalphG is offline   Reply With Quote
Old 04-06-2015, 08:03 PM   #3
V12Bill
V12Bill's Avatar
I used JB Weld to repair my steering wheel also. After a year or so it appeared to shrink the the repairs are visible. Maybe I should have let the JB Weld cure for several days before I started to work it. I see that the directions say that it can be machined.
V12Bill is offline   Reply With Quote
Old 04-06-2015, 08:11 PM   #4
al pa.
I used PC-7,no cracks,about 5 years.
al pa. is offline   Reply With Quote
Old 04-06-2015, 09:52 PM   #5
totto
totto's Avatar
I used PC-7 as well and that was 10 years ago and painted the wheel with black acrylic lacquer. I follow the book: Steering Wheel Restoration Handbook by Jack Turpin. I bought the book from Eastwoods. Has some very good info.
Henry
totto is offline   Reply With Quote
Old 04-06-2015, 11:08 PM   #6
Lawson Cox
Lawson Cox's Avatar
PC7 over JB weld any day of the week.
Old 04-07-2015, 02:10 AM   #7
peewee2you
peewee2you's Avatar
I just did my VW steering wheel was in very bad shape, used PC7 one reason is no sag or drip and can work with it up to an hour, and is workable also with denatured alcohol and icing knife to minimize sanding etc. They also make a product called Fix It Stick which as well is a 2 part epoxy, you simply cut the portion needed nead between your fingers or palms and press into joints etc. I will try my hand restoring my 47 Ford wheel next. Here are a few photo's
this one photo below had a section of 1/2" in height and 3" in length completely missing I used the spray can cap as a foundation along with a piece of was paper as a membrane between cap and PC7 as it does not stick to wax paper so I could remove cap after it dried.
photo below all sanded nicely and ready for primer coat
primer coat below:
base coat below:
Needs another base coat, then some clear and good to go. I had never done this before watched a youtube video and figured what do I have to lose, a repro cost $550.00 spent about $20 in material, used 60 grit, 100 grit, 800 grit..sandpaper
peewee2you is offline   Reply With Quote
Old 04-07-2015, 03:15 AM   #8
1938 Woody Cape Cod
1938 Woody Cape Cod's Avatar
PC-7 is the way to go.....................
1938 Woody Cape Cod is offline   Reply With Quote
Old 04-07-2015, 07:53 AM   #9
Admiral
Admiral's Avatar
Nice work, guys! I like these repairs, they look great and are VERY affordable to do yourself.
Admiral is offline   Reply With Quote
Old 04-07-2015, 11:06 AM   #10
Kube
Kube's Avatar
PC-7 was the best for years upon years. I used it myself for many years and many wheels with great results.
However, nowadays you might want to consider body filler designed for plastic bumpers, etc. It is specifically designed to withstand temperature extremes, shocks, and will not shrink.
Old 04-07-2015, 12:46 PM   #11
Fourdy
Fourdy's Avatar
I used the PC7 also. I had quite a few cracks to repair. I use a dremel to help key in the epoxy. D/P prime, base coat clear coat. By the way. The trim is real bird's eye maple. That took a little work. lol
Fourdy is offline   Reply With Quote
Old 04-07-2015, 03:29 PM   #12
OLD REK
OLD REK's Avatar
PC7??? Never heard of it......or is it another "Only in America" product??
OLD REK is offline   Reply With Quote
Old 04-07-2015, 04:44 PM   #13
Jay in Mass
That's what I've been using for years and it has worked well for me. I especially like the fact that it has some resistance to it like the plastic bumpers and it does not shrink.
Jay in Mass is offline   Reply With Quote
Old 04-08-2015, 06:53 AM   #14
FrankWest
FrankWest's Avatar
Today you can get Black JB weld.
Did you do the work with the wheel on the car?
FrankWest is offline   Reply With Quote
Old 04-08-2015, 08:38 PM   #15
jrhaelig
jrhaelig's Avatar
OK - so PC7 is better and I could have gotten black JBWeld. I did do it with the wheel installed so it was only about an hour invested.
If it blows out in 8 or 10 years I'll do it over.
John Haelig
Bridgewater, NJ
1939 Ford Pickup
1939 Buick
Old 04-09-2015, 07:10 AM   #16
FrankWest
FrankWest's Avatar
Good to know.
Maybe I have a wrong attitude... But with a cars this old I am always afraid of taking things apart unless I really have too. Because, Bolts and parts can become rusted solid into one piece. Where these was once a nut and and bolt and fitting....Now it has become one solid mass..That could hold well for the next 30 years, but if you try to dissassemble it you could break surrounding parts that were perfectly good.
I would rather slowly and carefully fill the cracks in my steering wheel while on the car.
Funny, I remember a post on this board where someone said,
All that needs to be done on his car was to remove all the parts, strip them and the paint and reinstall..."That should not cost much? Right!"
The guy that asked this question probably never tried to remove ONE rusted nut before. VERY FUNNY
Old 04-09-2015, 07:45 AM   #17
jimTN
What is PC7 and who sells it?
jimTN is offline   Reply With Quote
Old 04-09-2015, 08:24 AM   #18
JSeery
JSeery's Avatar
http://www.pcepoxy.com/
http://www.acehardware.com/product/i...ductId=1409482
http://www.pcepoxy.com/our-products/...oxies/pc-7.php
http://www.amazon.com/PC-Products-Tw.../dp/B008H4QSAW
http://www.ebay.com/sch/i.html?_nkw=pc-7+epoxy
About 15-20 sec on the internet will provide you answers!
Old 04-10-2015, 07:39 AM   #19
Cecil/WV
Cecil/WV's Avatar
Lowes
Cecil/WV is offline   Reply With Quote
Old 04-10-2015, 04:18 PM   #20
peewee2you
peewee2you's Avatar
FrankWest, you are correct unless you know how it comes apart and have the correct tools, usually best to leave it alone until you know.. because at times can lead to bigger head aches. Perhaps the JBWeld has added the additional strength so that at some point you can remove the wheel and touch it up a bit with some paint, then again not everything has to be perfect. Good job..
