04-05-2015, 11:13 AM | #1 |
Ford/Curtis key blank question?
I think I know the answer, but want to conform it. My Curtis key book lists a H-4 for the door/glovebox for a 46-48 Ford car. Was that number replaced by the later H-5 blank? I think it is a Ilco 1125? blank. It's been a while since I've used my Curtis #14 cutter and want to use the correct blank.
Barry 50 F-1 |
04-05-2015, 11:19 AM | #2 |
Re: Ford/Curtis key blank question?
I use H5 or Ilco 1125H. All the old blanks aren't available now.
04-05-2015, 11:35 AM | #3 |
On my 47 the key for the door and ignition is a Ilco 1125F and seems to work fine.
04-05-2015, 12:52 PM | #4 |
Barry,
I have enclosed a picture of standard Hurd blanks with their corresponding Curtis (H code) and ILCO (1125 series codes) written as notes. Also be aware that the H series are backwardly compatible blanks (from H11 back to H2) for cutting on your Mod #14 cutter (uses the H carriage for all; NH depth cutter for all after 1936, FH, FJ, FK codes forward; HCZ depth cutter for all before 1936, FB, FC, FD). You can sometimes still find these old obsolete blanks at old locksmith shops. I pick them up every time I see them. I have them available for purchase as well. Also going to be at the Charlotte AutoFair this next week for lock/key consultation and sales. Look me up if you are coming, Blue Field space BBB-093. Hope this helps. Regards, John McClure |
04-06-2015, 09:22 AM | #5 |
Barry 50 F-1 |
