Old 04-04-2015, 11:13 AM   #1
George D
George D's Avatar
Default Spring covers
Just bought a new set of leaf spring covers for the 30 coupe. Was wondering what type of lube to soak into the pads. Do you guys use grease, engine oil, gear oil, what works best. Thanks
George D is offline   Reply With Quote
Old 04-04-2015, 11:17 AM   #2
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Default Re: Spring covers
i used Red Grease on the springs and 600WT on the cover pads. VERY happy with the results.
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 04-04-2015, 12:31 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I've done the same with the covers I've installed for people.
BTW, I know of at least two different makes for the covers, and I found Bert's in Denver and Little Dearborn in Mpls. had the better covers.
Old 04-04-2015, 09:02 PM   #4
glenn in camino
glenn in camino's Avatar
I use chassis grease on the spring leaves and 600W on the cover pads.
glenn in camino is offline   Reply With Quote
